Question about Maytag Neptune MDG6700A Gas Dryer
Maytag MDG6700A front load dryer. Worked fine yesterday. Today, try to turn on - hear click and won't turn. Then another click. Error codes: Stuck key - 55 cycles ago No wet clothes - 56 cycles ago Please Help!
  • jcannizz3 Jul 31, 2010
    Dryer will not start. After pressing start, one click heard.
  • 4,323 Answers
Hi
If your dryer doesnt work then please check whether all the wires are hooked up to their corresponding terminals. Check for a Blown fuse or circuit breaker. Also make sure that the Door switch is functional and the door is closed.
Disassemble the dryer and check whether the Control Board is operational and Drive motor is functional.
If this doesn't resolves the issue then please check motor winding resistance: 2.88ohms between pin #3 and 4 3.5ohms between pin #4 and 5. For more information please refer the service manual for your Dryer. You can get the service manual for your dryer from this link---
Maytag MDG6700A Dryer Service manual
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 31, 2010
  • 10,319 Answers
  • jcannizz3 Jul 30, 2010
    I have the manual from when we purchased the unit less than 5 years ago. The controls/lights on the unit are working, but when we press start, nothing happens other than a click. I think the error codes are unrelated to the problem.
Error codes 3 and 10
need to test with multimeter, door code error could be a faulty door switch which would hinder machine from operating. I suggest checking the glo bar and ceramic igniter for the going off problem, in electric dryers maybe in gas as well bad motor windings can cause it to go off and on?
Aug 17, 2014 | Maytag Neptune MDG6700A Gas Dryer
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Error message LE5E and would only oparate prewash
it's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Kenmore Electric Dryer Model 68731
does the dryer have a gray back panel if it does then take it off the fuse may be bad its a small 1 in in diamiter white with 2 wires going to it replace it if the dryer has a front bottom panel in front then it is in there fuse is bad that is your problem
Aug 18, 2007 | Kenmore 659 Electric Dryer
Maytag Neptune MDG6700A Gas Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
