Question about Briggs & Stratton Garden
Mountfield SP550 lawnmower engine diagramme
Mountfield SP550 lawnmower engine running too fast, throtle open flat out
5 Suggested Answers
  • 5 Answers
SOURCE: Tecumseh 4.5 HP mulcher lawnmower - engine runs fast
there are a couple things you can do to maybe make the mower run without choke being on, remove the carb, disassemble float bowl and use a bread tie to clean out the jets and tubes. while you are inside the carburetor float assy, check the nut that holds the float bowl and make sure that the small hole is open, to test this yiu can blow into the hollow of the nut and see if there is air escaping or not, this entails getting the taste of gasoline on yiur lips, but a small price to pay as oposed to a mower shop service charge. i remedied my problem with a bread tie to clean the jets(openings) some are large enough to use a small paper clip. once you are relatively sure yiu checked and cleaned all the tubes, jets, and holes, reassemble the carb and put it back on and give er a yank see what happens, you'll probably find this worked and fixed your problem,
Posted on Jul 29, 2009
mowerman1857
  • 389 Answers
SOURCE: how much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Posted on Sep 15, 2009
  • 279 Answers
SOURCE: Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
Posted on May 28, 2010
SOURCE: How do I change a worn Carburettor Gasket and
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Posted on Aug 11, 2010
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Adjusting the carburettor springs on a mountfield sp530 to run correctly
most governor springs do have slack... they are designed to apply pressure during operation... the governor tries to run the engine wide open, the governor spring brings it back to a safe usable rpm... most small engines run well between 3200~3600 rpm's... I don't know what engine you have so I can't help more
Oct 20, 2014 | Garden
How do you change the oil in a mountfield LS45 Lawnmower???
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
Thanks for your question @ FixYa.com
May 19, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
May 28, 2010 | Mtd 22" Yard Machine Push Mower
How much oil does a mountfield omega lawnmower take
Sep 13, 2009 | Garden
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
May 06, 2009 | Garden
Garden Logo
383 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
