Question about Vintage Keeper Koolspace chillR Cooling Unit
Compressor doesn't always keep temperature setting. Sometimes it
Compressor doesn't always keep temperature setting it is set to. The temperature rises as if for no reason even when the door has not been opened and even though it is not in a hot area or affected by any sun.
The unit I have is the Vintage Keeper Tuscany 110 and the cooling unit is Koolspace minikool Ver 11-120v
4 Suggested Answers
SOURCE: moaning & groaning noise
your koolspace is loosing refrigerant slowly. the solution is to buy another one, because koolspace people changing their design every year so you as a consumer would not repair the cooler rather buy one new from them. what a sad way to do business. so do yourself an act of kind, do not buy koolspace, buy another brand and modify the hole to fit it in.
joe
Posted on May 17, 2008
  • 6 Answers
SOURCE: I have a Koolspace AA6 Tuscany free standing unit.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
Posted on May 19, 2010
  • 1456 Answers
SOURCE: I have a Vintage Keeper
Hello
The problem lies in the thermoelectric cooling module.This part should be replaced. Finding this part on ebay can be done by searching for "thermoelectric cooler". If the exact part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected.
Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
Posted on Jul 12, 2011
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good...
the compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Jul 05, 2008 | Refrigerators
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Kenmore 580.15151500 Compressor doesn't turn off
Most likely is a issue with the temperature sensor that when it reaches the level selected is not turning the compressor off.
Jun 15, 2012 | Kenmore Room Air Conditioner
Need manual for dac 8075ee air conditioner
I split this into 3 sections since I'm verbose.
1. Reasons to use it
2. Theory behind a/c and how it works
3. Steps you need to take
1. This is an easy method of reducing your FE losses due to A/C while retaining some of its benefits. I have to use my A/C when I'm dressed up in a shirt and tie as well as when my wife and/or baby are in the car, and I use this to keep everyone, including my wallet, happy.
2. Basic air conditioner theory: Your air conditining is operated by an engine driven compressor, then two "radiators"; a high pressure, hot one that is warmer than the outside air, and a low pressure, cold one that is cooler than outside air. Thermodynamically speaking, when the compressor does work on vaporized refrigerant to compress it into a liquid, its temperature increases. This is an adiabatic process. The high pressure refrigerant travels from the compressor to the condenser, which is in front of your car's engine-cooling radiator. Since it's now very hot, it loses energy to the outside air flowing through it. After losing energy, it travels to the inside of the car, passes through an expansion valve that allows a small amount of refrigerant to pass through. The refrigerant then enters the evaporator core, an area of low pressure. The liquid refrigerant evaporates, absorbing energy from the air inside your car, and then returns to the compressor.
Your compressor does not run all the time your car is on; it also doesn't run all the time your a/c is turned on. Most cars' expansion valves are thermostatic; they work to maintain a constant temperature within the evaporator core. If the expansion valve only allows a small amount of refrigerant through, the pressure in the high side of the system doesn't drop. A sensor detects this and disengages the clutch on your a/c compressor.
Therefore, if you do what you can to keep the evaporator core cool, you can decrease the percent of time your compressor is running.
3. What to do: Two things will allow you to keep your evaporator core cool and your compressor clutched off. First, always use the recirculate function on your climate control. Already cool, dry air flowing through the evaporator won't warm it up as much as warming fresh air from outside.
If your car doesn't have a recirculate switch, chances are that it has a "normal a/c" and a "max a/c". Use the MAX! This seems counter-intuitive, but since the recirculating a/c works better, it's labeled as such, and it's also more efficient.
Second, once you get your car to a cool enough temperature, adjust the blower fan to the lowest speed setting. You still get cold air blowing on you, but the smaller volume of air that flows through the evaporator, the cooler it will stay.
Using these two steps, you can have your a/c and afford to eat for dinner too
Jun 08, 2012 | Danby DAC8003D Air Conditioner
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
Power button indicates a cooling mode but I don't hear the compressor come on and the air coming out is not cool. Seems to have worked earlier this summer but sometimes the cooling seem spotty. Tried...
You may not have the temperature set low enough to make the compressor turn ON. Lower the setting until it does. This will give you an indication, where you need to leave it set.
Thanks for choosing FixYa.
Aug 27, 2011 | Amcor ALD12000M Portable Air Conditioner
Freezer is no longer keeping ice cream solid/frozen
Ice cream is usually kept at -10 degrees to stay firm. Need to check temperature. Look at condenser coil for cleaning. This is usually the most simple and common issue. If not making the desired temp, and the temperature control is set for that temp, and compressor run constant, it is a refrigeration issue. If compressor does not run constant, then a control issue.
Jan 24, 2018 | True GDM-49FC Refrigerator Commercial
Thermostat position?
The thermostat control alows you to set it at whatever your desired room temperature is. It will keep the compressor on until it reaches your desired setting and then turn the compressor off.
Aug 14, 2009 | Frigidaire FAH08EJ1 Air Conditioner
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
May 24, 2009 | Victory URD-27-SBS Stainless Steel
Furniture Logo
100 people viewed this question
Top Vintage Keeper Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
