Question about Canon PowerShot A520 Digital Camera
My 3 year old son was playing with my camera, and now ir is not working. with fresh batteris the on switch works but does not turn on. The screen is black.
    Master:
  • Canon Master
  • 443 Answers
Memory card slid may need to be mooved or it is not in place properly
Posted on Dec 26, 2011
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Does not turn any equipment on or off. has power but does not communicate at all. I have rebooted, etc. but no luck. Old remotes still work. It appears that IR is dead.
If you have confirmed that the remote's IR emitters have failed and you are out of the warranty period (1 yr), you have a few choices. You can contact Logitech. They will usually issue a 50% discount on a new remote. Or, you can try to repair the remote yourself using the guidance in this article: http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
Or, you can have it repaired for $14 (or less if you haggle) from this Ebay seller: http://cgi.ebay.com/We-can-Repair-your-Harmony-880-Remote_W0QQitemZ200437939363QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eab083ca3
Jan 16, 2010 | Logitech Harmony 880 LCD Remote Control
My Panasonic DMC-FX30 is less than a year old and is failing. It won't take a picture, constantly requests to turn the off and back on, and now pretty much freezes up on the screen and won't react to any...
There could be a few things. One thing is for sure though. If it is less then a year old. Don't waste another second. Have it sent into the manufacturer to be repaired under warranty.
www.panasonic.com
Thanks,
Lee
Jul 11, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Bought the 88379 digital camera for my 6 year old son for christmas and he is very disapointed with it as we can not get it to work. when we try to switch it on there are just lines on the mode screen and...
take camera back and get a refund seems like the firmware in camera ha sgot corrupt. doyou have the right kind of batterys in it
alakaline reg rechargeable? check the book that came with the camera for proper battery 's
Jan 01, 2009 | Sakar 57482 Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Remote control quit working
Batteries can be bad or installed improperly. If you know someone with a digital camera that has an lcd display, point the remote at the camera while someone is looking at the camera's image in real time. Infrared will appear as white light to the camera's CCD "eye". Cool trick.
Remember, IR is line of sight. Make sure nothing is blocking the path between the remote and the TV. Also IR remotes and fluorescent lighting doesn't mix.
Nov 24, 2008 | Radio Shack (15-2147) Remote Control
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
My camer won't turn on
Does the lense extend when you power it on in "snapshot"mode?
Could be the switch is sticking. These cameras use concave cup button that mash on gold foil on the circuit board. Could be a bad switch. $$$$$ costly.
Interested in selling it?
Email me
KQQLdevice@aol.com
Oct 26, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Purple Pictures
This is a CCD sensor problem and should be replaced. Try to have it done free of charge by Sony even though your camera is an old model because CCD sensor should last 10 years +.
Aug 17, 2006 | Sony Mavica MVC-FD73 Digital Camera
Canon PowerShot A520 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
