I having problems wast of money I try do my device camera for long time now
Try removing the Battery out of the camera. Then hold the Power switch on for one minute or more without releasing switch.
Refit Battery and try switching on again. Keep fingers crossed, it worked for me.
SOURCE: When i turn on my camera it says Turn the power off and on again
Banging it worked! I wish I had done that hours ago when I needed my camera!
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1
Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
?Ā· Turn off the camera.
?Ā· Remove the battery pack.
?Ā· Press and hold the power button for 30 seconds.
?Ā· Allow the camera to remain without power for 60 seconds.
?Ā· Reinsert the battery pack.
?Ā· Turn on the camera.
Thanks,
KenSolutions
FixYa
