Question about Omega Rear Drive Wheel Snapper Mowers
No Spark I have a Snapper SR 930 with a Briggs & Straton motor (28A707) any Ideals
Snapper rear engine mower wont go forward or reverse
the drive system on that mower is a rubber friction wheel after time the rubber become brittle and falls apart and also wears it you tighten the vent on the fuel cap and stand it up on the rear bars you can see it it rides on a alum wheel held in by 3 or 4 bolts easy to change if it has electric start you need to remove the battery if you leave it up on it back for more the 30min
Jun 13, 2012 | Garden
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
Need linkage diagram for 6HP briggs carb from snapper comet mower
Try looking up your product here: http://www.snapper.com/manuals/
If you can't find what you need there, please try to contact Snapper at: http://www.snapper.com/contact/
If it's the linkage on the engine itself, try Briggs & Stratton's website here: http://www.briggsandstratton.com/maint_repair/manual_and_more/
Hope that helps!
Apr 30, 2009 | Snapper Electrical Supplies
Omega Rear Drive Wheel Snapper Mowers Logo
162 people viewed this question
Top Omega Garden Experts
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Al Schrader
Al Schrader
Are you an Omega Garden Expert? Answer questions, earn points and help others
