Question about Speed Queen AES28AWF Electric Dryer
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
  • 999 Answers
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Posted on Jul 30, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Dryer wont heat
The only thing left to check is the voltage at the heating coil. IF it is not present then the timer or relay is bad.
Jul 22, 2013 | Speed Queen AES17AWF Electric Dryer
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
My speed queen dryer (model 170) is over heating. Clothes are extremely hot to the touch and wrinkled.
check the dryer vent to make sure nothing is blocking it, Hot clothes and wetness is usually caused by venting problems,, if the moisture and air can't leave,, you end up with your problem
May 27, 2011 | Speed Queen Dryers
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Mar 12, 2010 | Speed Queen Dryers
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Speed Queen AES28AWF Electric Dryer Logo
93 people viewed this question
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Marvin
Marvin
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
