TV proj RCA year 1997 model p46734ba ctc178cr series
Please you have for TV proj p46734ba 1997 param#range for ctc178cr series for number 1 at 22 please for adjusment chassis and crosshatch generation
i speak englis little bit sorry
if you have... send me at charbonneau_roger@hotmail.com
tank you
  • FixCharo Apr 24, 2008
    oupss.. my tv is rca is P46734BADX2 ctc178cr series
  • 8 Answers
SOURCE: Dot & Crosshatch Generator question
this is a piece of equipment that injects a cross pattern signal or a dot signal (such as the little game connect the dots) and you align the colors exactly on the dots or the cross boxes such as you have already experienced with your cross hatches. i would think more along the lines of another resistor, connection, or something real close to where you already are, sounds like you almost got it just need to look one more time.
good luck stereo tech
Posted on Feb 03, 2008
  • 2920 Answers
SOURCE: TV wont turn on
how the inverter checked out
Posted on Sep 02, 2008
SOURCE: Need download (EASILY OPENABLE) RCA CTC 169 PROJ TV Schematic / Serv Man FREE
The file you are talking about requires 15 pieces to create the file CTC169PTV.part15 is one of these parts if you need this file send me an email i will sent it to you
Posted on Nov 22, 2008
  • 668 Answers
SOURCE: Mits WD52725 DM Board
Dan,
I would causion removing the DM board in this unit. It is buried and the real problem is that there is many capasitors across all the boards of the chassi assy that could go bad. Replacing the ones on the DM will not guarantee fixing the dreadful green Blinking
LED. The only way I have known it to be fixed properly is to actually send the chassi assy. to Mitsubishi for them to refurb it. The negitive thing is that it is exspensive and they will only refurb it through aAuthorized Misubishi Repair Facility.
Cost would probly be around 800.00 to 900.00.
I know it is not what you wanted to hear,
but that is mt take on it.
Hope this helps,
Skyassoc
But it is the
Posted on Jun 19, 2009
asnowman
  • 788 Answers
SOURCE: 52" rca hd proj. tv model # d52w23
Your symptom sounds like a damaged convergence IC, whick you have found to be true.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sink2.gif compound that is on the heat sink2.gif, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 04, 2009
Rca rear proj. 1993 model p46151wk tv just went dead no picture no sound no light on power button I only found 1 fuse it is good
Take a look at CR4118, and the capacitors around the power supply regulator chip. You likely have capacitors that are dried out. They can take out the chip, and Q4101, the 'chopper'.
The web site: http://eserivceinfo.com/ has a program for the CTC169 series of RCA projo's that is very useful in finding the fault that causes the condition you describe. Just enter ctc169 into the search box. Or go to this URL:
http://www.eserviceinfo.com/downloadsm/4999/RCA_proscan.html
tom
Feb 25, 2010 | RCA Televison & Video
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
52 RCA REAR PROJ. TV WONT TURN ON.
The problem will be the deflection board (left hand side board when looking from back of unit.Part number is 258762 is no longer avaible thru rca but you can contact tristate module or pts electronics-you can even google the part number
Sep 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
My rca tv 20f424t doesn.'t show thw correct
That is the Digital range of channels, since it is digital you will not need a converter box for this model. Their is also an Analog range of channels which is the primary setting, You will need the factory remote to switch from Analog to Digital... Without that remote you might have a problem their isnt a way to switch within the menu settings, good luck!!!
May 11, 2009 | RCA Televison & Video
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
RCA model hd56w58
the part number for the high voltage transformer, according to another post for this tv is 258512. See below:
noavatar_s.gif jdenton77
Rank:nonexpert_s.gif Apprentice
Rating: 85%, 1 votes
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv
Jul 08, 2008 | RCA HD56W58 56" TV
Check here for the download.
You may want to get a new winrar download to open the files.
Good Luck.
Mar 02, 2008 | Televison & Video
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
