Question about Kenmore HE2 Plus Front Load Washer
My Kenmore front load He2 fills with water in the dispenser cup then spills out from the dispenser cup onto the floor. Can anyone help?
SOLUTION...DON'T BUY THIS PRODUCT. THEY ARE LEMONS.
Kenmore you failed. Claudia Bennett, Boston
claudiabennett80@aol.com
I should have kept the older unsophisticated model ...my basement smells...I did not know I am supposed to be a technician to wash my clothes!!!!!!!!!!!!
Posted on Apr 13, 2011
My kenmore he2t is spilling water out of soap dispenser
The dispenser is removable like a car ashtray. Put it in the dishwasher and run it through a cycle Or soak it in hot water and clean it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2012 | Kenmore HE2 Plus Front Load Washer
The hose that drains the machine is spilling out water. Is there some kind of blockage in the line caused by detergent??? The plumber snaked the line but water is still spilling out of the drain pipe.
is the hose in the washtub?  It's not laying on the floor is it ??  if it is, it has to be 36 - 42 inches off the floor or water will just go in and out...
Jul 28, 2010 | Kenmore HE2 Plus Front Load Washer
The Liquid Fabric Softner dosn't dispense completely. Approximately 1/4 of it is left in the chamber.
the problem is that the hole that drains the chamber is partially blocked with dry fabric softener. pour a cup of viinegar in to the dispenser and do the wash using the hot water cycle and no clothes. this will clean it for u
use white vinegar if u have it or apple cider vinegar
Aug 17, 2009 | Kenmore HE2 Plus Front Load Washer
Does anyone know the code to make a HE2 Plus "spin only"?
select the Spin/Drain cycle. any special code would have been the service/diagnostic mode but that wants to run a factory test which involves water fill and agitate
Apr 28, 2009 | Kenmore HE2 Plus Front Load Washer
The water softener dispenser fills with water each wash...
This is pretty typical....other than dumping the drawer out each time, I have not seen a solution for this complaint. If it is having trouble dispensing softener, you could try raising the front legs 1/4", this helps create a better siphon in the dispenser.
Apr 21, 2009 | Kenmore HE2 Plus Front Load Washer
Bleach and fabric softner despenser liquids not being used.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Washer fill with water when it is not on...
remove top 3 screws in rear of top panel..left rear corner water valve where hoses come in replace it not shutting off completely
May 19, 2008 | Kenmore Elite 45986 Front Load Washer
Water fill
your hose from the dispenser to the tub might be twisted or kinked but it is about 2in in diameter and seems unlikely, but anything is possible
Oct 14, 2007 | LG WM-1832C Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
