Need directions for reconnecting equipment (box, coax, rj45) for comcast voip service. another party disconnected from pc and i've been asked to hook up again; want to avoid trial and error. help!
  • tdkliewer Jul 31, 2010
    much appreciated.
  • 223 Answers
Hi tdkliewer,
this should be very simple:
Step 1: Make sure that all of the equipment is powered down.
Step 2: Connect the Modem with the coaxial cable.
Step 3: Connect the category 5 (ethernet) to your router or IAD, (you may have a combo router, voip box) into the line in port. If you have a combo device jumo to step 5.
Step 4: If you do not have a combo device plug a cat5 cable from the router port 1 to the voip switch.
Step 5: Connect rj cable from the voip box to your handset.
Step 6: Turn on all of the equipment and give it a few minutes to configure.
Step 7: Pick up the phone and verify dial tone.
If you do not have a dial tone check your internet connection and try rebooting the modem and the router.
If you still don't see any connectivity on the modem contact comcast.
Their tech support line is: 1-800-266-2278
Al
Posted on Jul 30, 2010
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
I need instructions on hookup to Comcast Cable
I'm sure Comcast will be more then happy to direct you on phone step by step on how to do this... I'm sure you pay them every month.. don't you.
Best way I'd hook up is through the 5 RCA jacks monster cable.
3 for picture... green red and blue. then the 2 red and white for sound. match colors cable box TV.
if asking to connect direct cable to box.. your tv will pick up either some or nothing. you still need the Comcast cable box.
Jun 02, 2013 | Philips 20PF5120 20 in. EDTV-Ready LCD...
How do you hook up to cable, comcast
If no box, then directly to the coax connector on the rear of the set, if using a box set to the channel the box is set for (usually 3 or 4) and output coax from box the coax fitting on rear of set.
Leave set on three and power box and change channels with the box.
Dec 17, 2012 | Toshiba 50H82 50" Rear Projection...
I can't get my Comcast cable channels to display on my Hitachi HDTV..how should I fix this?
A very well written question and I think you have provided your own answer.
this set uses a antenna switching assembly and they do fail. It could also be a bad tuner--note that the other owner got blu ray and such on it which are not via the coax fitting.
If your box has audio/video output jacks (like the blu ray) connect them to one of the rear audio/video inputs on rear of set and select that input on the set---box will then be used for channels but connection will not be via the coax but via that input.
If the box does not have those outputs get another--most providers do not charge for a box with those outputs on it.
If works you are just bypassing the tuner where your problem seems to be---those antenna networks are no longer available from Hitachi.
SD TECH
Jun 01, 2012 | Televison & Video
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
Jan 18, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HAVE NO DIAL TONE SOUNDS LIKE AN OPEN LINE
your service is hooked up? do you have access to your phone box? House or apartment? can you trace the lines? if you have access to the phone box, you can open it up and plug a phone directly into it to test.
Jul 23, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Lost installation instructions
First unplug your current antenna from your tv and plug it into the "Antenna In" coax port in the back of your converter box. Then take coax and run it from the only other coax place on your converter box back to where your antenna was previously hooked in on your tv. If after you run "scan" on your converter box it is saying " no signal " or "signal lost" or something along those lines, go to www.antennaweb.org to see what type of antenna will best fit your location then print it off and bring it to a local store that sells antennas, they should be able to direct you to the right one.
Jan 18, 2009 | LGDVT418 System
Lap top not connecting to signial
Yes you can reconnect your router. Whoever did that at Comcast had no business doing that and should be reported and return their equipment back to Comcast asap. It could appear on the bill.
I have a Linksys modem on my Comcast router and it works fine. I don't let them touch it because it uses T-Zones at home service for phone use and it uses a special router to manage it since it has a sim card to run the phone line.
Vonage equipment can be used as well.
I wonder if they were trying to put their phone service onto your system?
Jul 18, 2008 | Linksys Wireless-G Broadband Router
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
