Question about Garden
My cp 734 air wrench wont turn just blows air through the trigger can anyony help??
    Brigadier General:
  • 4,090 Answers
It will require new seals fitted by a repairer. It's not a DIY
Please rate my help++++hanks for using FIXYA
Posted on Jul 30, 2010
Where can i buy "block ca141848" for cp air wrench 734
You can try ereplacenmentparts.com
Follow this link and they a picture of the parts that you are looking for! Block CA141848 for Craftsman Power Tool eReplacement Parts
Hope this helps.
May 30, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
CP 734 Trigger Broken
If you are still looking for this part I would call power tool repair at 330-630-0022 and order that part number. From the breakdown it seems you have the correct part number
Jul 24, 2012 | Chicago Pneumatic 1/2" Air Impact Wrench
I just fixed my cp 734 i cant find how much oil should be in hammer unit please help thank you
This is from the CP734H manual.
Check clutch oil once each month. Use 3/4 oz.
(22ml) of SAE#30 oil or equivalent.
Make sure the oil is non-detergent.
Mar 25, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Oct 18, 2009 | Craftsman 1/2" Impact Wrench
The 734 cp impact wrench has not been used for a couple of years and appears in excellent considtion however, I do not remember how to oil and/or remember the impact ratings using the dial; is there a...
Put 4 or 5 drops of oil into the air line opening. Connect an air supply and burst the trigger a few times. The settings are 1-less 4 more. It's all up to the application and they are not specific settings.
Oct 10, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Sand has entered my CP734 impact wrench.
Check the following website. It is a pdf file, so you will need Acrobat Reader, which is available on this website. After it loads, it lists various CP model numbers on the left side, so scroll down to 734 and click on it( it says 734 OBS) and it will open an exploded view of the breakdown of the CP 734 impact wrench. On the Acrobat toolbar, you can expand the picture as much as you want to and print it.
Good Luck!
Jul 31, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
My 1/2" CP air wrench just blows air thru when I pull the trigger
I have ran into this many times, even though you keep it oiled dirt can and will get inside. what you need to do is unscrew the 4 alen head bolts and pull the nose off. You will see a shaft that looks kind of like a crankshaft with 5 or 6 flat carbon fiber plates sitting loosely in groves around the shaft. pull those out and clean them with solvent and check them for damage or wear. clean the inside of the gun with solvent or brake cleaner, reassemble and it should work fine. If the plates need replaced then you should be able to order them from a tool supplier,and they are not that much.
Jan 17, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
