Question about Sylvania 6240VD VCR
Is there a tracking system on this VCR? We have several tapes that are jumping or skipping. Sylvania 6240VD
  • Sylvania Master
  • 5,515 Answers
All VCR's have tracking, it's not however clearly marked on the remotes often. Some use the up-down channel channel selector or other keys, while some have it on a menu somewhere.
It's also worth cleaning the heads sometimes with Servisol Video 40. Just take the top cover off and spray both the big video head and the smaller heads. Let it dry up before trying a tape.
Posted on Aug 01, 2010
I have a sylvania VCR/DVD combo and the VCR has trouble playing my tapes. It gets stuck and then the tape gets caught and I have to take the top off to get it out. I also have a sylvania TV with VCR...
i suggest you to buy a Maxell VP-100 VHS Dry Tape Video Head Cleaner, the head of the VCR is dirty that cause the tape get caught or stuck. hope this help you
Jun 06, 2011 | Sylvania DV220SL8 DVD Player/VCR
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
I just bought one refurbished,what exactly does this mean?
It means it has been used, often by a previous owner (though not always). It has then been inspected and rebuilt to make certain it works. Generally the parts that can wear will have been replaced or anything that has a short life, such as belts.
Most places will offer some kind of warranty to cover this work.
Sep 30, 2010 | Sylvania 6240VD VCR
When playing a vhs tape the pics jump half way through watching. trying to record these old family tapes to dvd. is there a type of vcr i can buy to manually fix tracking or is there another way to solve...
There are two reasons that might cause loss of tracking halfway into a video tape. The first means you can't really do a lot about it. To check it is this is simple. When you get to the point the video jumps, stop the VCR and eject the tape. The look at the tape itself by lifting the flap at the front (push the small catch on the right side). Examine the section of the tape. If you see any damage to the tape (it should look smooth and shine) then it will never track properly.
Another cause of the jumping is caused by the take up reel, getting sluggish. Sometimes these are run off a belt, that becomes slack, replacing it could solve the problem, or it could be something else in the mechanism that's causing it.
There is another solution, particularly if the tape wasn't recorded on the machine that is playing it back. I haved used loads of different VCR's and I found that the tracking has never been set up right on any! This means that only the VCR it was recorded on generally gives the most correct playback.
Having said that it is possible to get a VCR with really good tracking. I have found that Panansonic VCR's have the best tracking. I currently have a NV-HS900 which can track just about everything, but you will only get one seconed-hand now.
Apr 07, 2010 | Televison & Video
VCR Tape jumps like the vertical hold is off.
Most VCRs use the channel Up and Down buttons for the tracking
Jun 30, 2009 | Panasonic PV-9662 VCR
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
Mar 16, 2008 | Sylvania 6260VF VCR
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
Tracking won't zero in
try cleaning the heads with a head cleaner or even a high grade blank tape letting it play for 20 mins.
hope it helps
wg
Feb 02, 2008 | Sylvania DVC840F
Jumping screen on sylvania 6240ve
Press the Channel up & down buttons at the same time and on most VCRs this deactivates auto tracking option. then press the up or down channel button to adjust tracking.You might try this first. pressing them both at same time reactvates auto tracking. This might not solve the problem but at least you eliminated one possibility.
Nov 12, 2006 | Sylvania 6240VE VHS/S-VHS playback VCR
Sylvania 6240VD VCR Logo
123 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
