Question about Sharp 32K-S400 32" TV
Cable coax came off back - Sharp 32K-S400 32" TV
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
A new one will have to be soldered onto the tuner. As long as it didn't damage the tuner, it shouldn't be too bad to fix. Our shop normally gets around $30 - $40 to put one back on.
Posted on Jul 30, 2010
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Tip
How to connect and record on a VCR when you have a Digital Cable Box.
Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
First here are the cables you will need.
3 sections of Coax cable (preferably RG-6 quality)
or
2 sections of Coax cable (preferably RG-6 quality)
1 RCA cable (Yellow/Red/White)
Now here is how you will need to hook up the cables properly.
1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
Now this is how you will need to set your VCR and Cable box to make your recording.
1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
2) Tune your cable box to the channel you wish to record.
*** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
on Jan 09, 2010 | Televison & Video
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
How to fix the antenna anolog cable connector that to coax cable connects to on back of TV.
Cut off the bad connector on the end of the coax cable. Go to Radio Shack, Home Depot, etc. and pick up a new twist-on coax connector, or a crimp on version if you have a crimping tool.
Twist the new coax connector on good and tight and you should be good to go.
Mar 30, 2010 | RCA HD52W59 HDTV Projection Television
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Coax cable broke off my wife tryed to put back in the cable line with coax insert broke off there was connector on the cable line she just jammed the bare cable line into the hole where the coax...
Yes there is a possibility that something shorted... remove the cable wire and unplug for 10 to 30 min and try plugging back in and restarting the set. otherwise the tuner probaly would need replaced. something any tv tech can do. AT the shop we replace these conectors al the time. just depends how bad the tuner is damaged.
Mar 17, 2009 | RCA Televison & Video
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Sharp 32K-S400 32" TV Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
