Question about Acer Aspire 5600 Series 5630-6951 Laptop
Resource Conflict - PCI Network Controller in Slot 02
System Bios Version V2.70
Bus: 06, Device: 01, Function: 00
ERROR
Bus: 06, Device: 02, Function: 00
ERROR
Resource Conflict - PCI in Slot 03
Bus: 06, Device: 04, Function: 01
ERROR
Bus: 06, Device: 04, Function: 02
ERROR
Bus: 06, Device: 04, Function: 03
Press to resume, to setup
PCI DEVICE problem i cant use wireless internet
  • oz_y Jul 22, 2008
    ERROR
    ERROR
    ERROR
    ERROR
    oz_y@live.com
    acer aspire 5100
  • staceyreeves Mar 13, 2009
    I have the same exact problem. Started as a problem with my wireless internet not working some of the time. Then it totall stopped working. Now this error comes up, I press resume and the loading screen with the window and the blue bars comes on but nothing happens and my laptop won't load at all. :(
    Sergeant:
    Champion:
  • 256 Answers
Check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
I have Acer TravelMate 4062 WLCi that had the same problem (Bus: 06, Device: 04, Function: 00), resulting the wireless adapter (Intel wireless 2200BG) not working. Actually the problem somehow related to another issue I had when I noticed my CUP usage shot up suddenly about 6 months ago. It turned out that my battery was dying and the system trying to look for the device (battery). Once I realized it was the battery that caused the issue, I unplugged the battery and just used AC power (always connected to wall outlet), and the CUP usage was not an issue any more. One day, I had to pack the laptop for travel, and it still worked during my travel. Once I got back from the trip, I did not take out the laptop and connect the AC power to wall outlet for about a week. Then when I remembered to connect the AC power to the laptop, the computer was off (reset back to 2005/01/01). I realized the CMOS battery was probably dead because I did not connect the AC power to the laptop. So I replaced the CMOS battery. But it did not fix the problem. And at the same time I started getting this Bus: 06, Device: 04, Function: 00 error that caused the wireless adapter to stop working. So I thought maybe I should purchase a replacement battery. Once I received the battery, I plugged in, but problem remained. I remember reading google search results that someone said to unplug the memory card and re-install it. I was very skeptical about this work-around. However it did work. Once I took out the memory card (2 GB), put the old memory card (512 MB) on, then removed it, then re-install the 2GB memory card, and powered on the laptop, the error was gone. I think you can give it a try by removing the memory card and re-install it.
Posted on May 24, 2014
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
Posted on Aug 29, 2008
alien_x
  • 281 Answers
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
  • 1087 Answers
SOURCE: Al encender mi ACER Aspire
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Posted on Aug 16, 2010
junk9
  • 150 Answers
SOURCE: when starting the laptop acer
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Posted on Sep 08, 2010
  • 8909 Answers
SOURCE: Bus: 06, Device: 01, Function:
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
Posted on May 02, 2011
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
4,030 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
