Question about Garden
My 550 series Bolens lawnmower won't start. When I prime the carb and pull the starter cord the engine will try to start for a second or two, then stop. Oil checks out, as does the gas it is brand new used once
2 Suggested Answers
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
Poulan pro pp033 33cc. I can pump the bulb pull the starter cord. it starts for a few seconds. then shut off. then I can do the same thing again. and I pump the bulb 6 times.
Your main jet in carb is clogged and needs to be cleaned out. Unit starts with prime and then will stop when no fuel is received by engine.
Jan 17, 2017 | Poulan Garden
Starting problem with admiral 16SE Petrol lawnmower
lack of fuel
possible water in the unit or blocked main jet
have the carby overhauled
Feb 08, 2018 | Admiral Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Aug 08, 2009 | Garden
Starter cord loose on Bolens 4.5 HP lawn mower
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
May 12, 2009 | Garden
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
