Question about Bissell Vacuums
There is a shaft that comes out of the pump of my Bissell 1623-1 Power Steamer with gears on it. The belt to the brush attaches to it. When I went to change the belt, the belt was fine but the gear itself with the small shaft on it was no longer attached and just dropped out. It looks like there might have been a bushing there, but no more. Any ideas?
reddevil6
  • 1673 Answers
SOURCE: Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Posted on Jun 03, 2008
SOURCE: directions for Bissell upright rug shampoo vacuum
need belt on brush
Posted on Sep 30, 2008
need to find directions for bissel rug cleaner
Thank you
Posted on Dec 02, 2008
SOURCE: I bought a Bissell 1695
Hello, I went to a local repair shop & was told that I may as well trash this Bissell 1695 model because very few parts were available & none were what I needed. Of course, I have to research things for myself & to try to keep from buying a new power steamer. Called Bissell Customer Service. CSR told me that the model was discontinued, none of the parts that I need are available & referred me to five authorized KY dealers (all of which are an hour or more driving time away). I am going to call all of them tomorrow & hope I can find a solution to one broken pivot arm that holds rotating brush roll. I found a helpful website that has a schematic and lists all parts that are available to order (& unavailable). There is also one service note regarding the parts that I need that says the entire base assembly with brush motor must be replaced because of a design change. Of course, it's not available either. Hope this helps some. The website is: hescoinc.com
Posted on Jun 16, 2009
SOURCE: Bissell magic steamer Model 1640- need faucet/hose
http://www.bissell.com/images/UserGuides/16311.pdf
Posted on Nov 24, 2009
Bissell power steamer brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
Bissell 1623 sprayed used water from tool
Hi Beverley, you may want to have your machine inspected by a Qualified Technician at one of our Authorized Service Centers.
Here's a quick link to locating an Authorized Service Center in your area. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 26, 2013 | Bissell 1623 Steam Cleaner
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
The gear that turns the belt on my bissell power steamer model 1697 m has come-off.Can it be fixed or replaced, and can i do it myself.??
I had the same problem and went to bissel .com and they sent me a parts replacement catalog,it was easily replaced, but before spending the $,bring it to your local vac repair shop and see if the bolt just came loose.r
Jan 27, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697w
First take off the belt cover on the side,
then turn it over, on the belt end of the brush roll, there is a red piece to hold in the brush roll, take out that screw and pull it off, the you can remove the end cap and cogged belt, Put the pump belt up thru the opening and around the bigger part of the pump pulley, grab the belt from the top side and put it around the motor shaft. Re-install the cogged belt, brush roll, cap and red lock.
Nov 07, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Power brush on Green Bissell power steamer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Sep 24, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
35 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
