Question about Watches
Whirlpool fridge-freezer #ET8CHEXSQ02 ----- Freezer is at -4F and fridge is at 70F. What part or parts are probably at fault? Thanks, Frank // Gramps // renthelp // BDCD928E
  • renthelp Jul 30, 2010
    Helpful is an understatement. This help is fantastic -- as to speed of reply, as to details, comprehensiveness, and aiming me towards unit pixs and other sources.
    Absolutely super duper service.
    Many many thanks,
    Frank // Gramps // BDCD928E
  • 2,272 Answers
It is the frost build up in the unit.so the ventilations are getting blocked and other components like fan,motor are getting bit slow and so this temperature is getting high/low. so first try the manual defrost reset procedure.Unplug the unit.Then empty both the sections in the unit.the fridge and freezer section.then keep the doors open for both the section.And let it remain for next 24 hrs.Then after that clean the leaked water in the unit with dry cloth.Close the doors and reconnect the power to the unit and turn on.Set the temperature to normal settings and check.In 3-4 hors time.It will start showing the results.If the problem exists then defrost reset did not helped and there is problem in the defrost assembly of the unit. one of the defrost components has failed,maybe the defrost timer, defrost heater, or defrost thermostat.New model board have adaptive defrost control board instead of defrost timer. ------- If you want to know how to disassemble the unit part by part.and how to remove the part and from where to buy the part please click on the link below http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153490
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 30, 2010
How do I put the back cover on a Waltham watch?
Try hooking the edge furthest from the winder at first, then work toward the winder.
If that isn't enough... warm the back cover with a hair dryer while you chill the rest of the watch. Serious as anything - the warmed cover will expand JUST SLIGHTLY while the cooled watch will contract JUST SLIGHTLY, maybe enough to snap that cover on. You can cool the watch in a freezer, but if you do... quickly snap the cover on while you hold the watch in the still-open freezer. If you take the watch from the freezer and leave it open at room temperature, it'll get moisture condensate inside. Leave it cold until the cover's on.
It also helps to wear cotton gloves if you use the heat-and-cool approach - then your hands won't appreciably cool the warmed cover or warm the chilled watch.
The watchmakers have a special watch press that squeezes the back into place - it's padded to prevent damage to the crystal, and applies a little extra force to the center of the back to buckle the rim outward just slightly during pressing. Like the opposite of a wheel cover for a car.
Jul 30, 2014 | Waltham Watches
Watch band replacement for Frank Gehry watch
I don't find watch band replacement for Frank Gehry watch anywhere
please I need one
Dec 29, 2012 | Fossil Digital Frank Gehry...
How can I clean the scratches on my Paul Frank TV watches?
Scratches on watches can usually be cleaned with a mild abrasive
such as Colgate toothpaste and water.
Rub a small amount of toothpaste on the scratch in a circular motion
and then apply a dab of water, continue to to rub in a circular motion
after applying the water. Let the mixture dry and rub in a circular
motion. Repeat the above steps until the scratches fade away.
This remedy worked on my watches as well as my faded
car headlight cover.
I hope it works for you.
Jan 17, 2011 | Paul Frank TV Watch Strawberry Cupcake
Have a Giorgio watch Movement #579-005 or 579-105 looking for a cross reference movement Thanks...Frank
There are millions of movements novadays. You have to get an eyeglass and examine your movement. Then submit all the details. Do not forget to mind if it is mechanical, quartz, solar, e.t.c.
Jan 22, 2010 | Watches
I cannot set the time or date on my watch. The
Hi Frank
Does the watch have a 'screwdown' crown on it or pull out crown (also known as a dust proof crown). A screwdown is usually on a model which has a waterproofing of around 100 meters (330ft) +
To change the date ( the quick way usually but not always) GENTLEY pull out the crown (or first unscrew if it's a screwdown) to the first 'click' you will feel it. then gentley wind the crown down towards the six or up to the tweleve (some change mostly its down towards the six) and Hey Presto the date changes automatically. This beats winding it through 24 hrs.
Now to change the time, from the date set one more gentle click, or two from the original (standby position). then you are free to move the hands as you please.
Hope this helps Frank
Jul 13, 2009 | Watches
Dive watch battery replacement
a local jewelry store or Walmart. while you wait.
Apr 03, 2009 | Casio DW290 1V Classic Alarm Chronograph...
Rotary watch
place the back plate in the freezer till its really cold itll snap right in there:)
Oct 17, 2017 | Timex 27191 Wristwatch
Raymond weil tango
I suggest taking the back cover off, removing the battery and reinstalling it again. Make sure the battery is installed correctly and is the exact type. Its very easy to put them upside down, Sometimes it may take a couple tries.
Jan 15, 2008 | Raymond Weil Parsifal W1 watch
Perpetual calender calender reset
Go to this link and click SMD series; http://www.seikousa.com/faq/operationguide.aspx# Hope it tells you what you need :)
Mar 23, 2007 | Seiko SMD008 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
