Question about Dometic Rooftop RV Air Conditioner
Not cooling, what kind of freon - Dometic Rooftop RV Air Conditioner
    Novelist:
  • 117 Answers
Either R-22 or R-134A. Look for a data plate. It will have the refrigerant in use and the factory charge of said refrigerant.
Posted on Aug 01, 2010
Refrigertor not coling how do i know what broke
You may have a freon leak. Low freon causes it not to cool. Call a repair man who has testers for this kind of problem.
Nov 10, 2014 | Kenmore Refrigerators
My 2000 buick lesbre doesn't blow cold air like it
Hi bennysosiris...
If your compressor is starting and stopping regularly and it is not blowing cool as it one did then I would say:
Yes you need to add some freon to your system...depending what kind of freon it takes if would be better to take it in to have a professional install your freon to the proper pressure and volume.
Please take time to rate me
Aug 03, 2011 | Air Tools & Compressors
What can i do to stop my A/c compressor from clicking on and off but still have cool air on my 1999 mitsubishi montero sport
Its calling for more freon when it kicks on and off. Add Freon.
You can buy freon at most any parts store.
Make sure of what kind it is. R-134 or r-22 Look under hood for the designation
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Heating & Cooling
It will hot cool on electric or propane. Could freon be low or could it be something else? How is the best way to check this problem? How much freon does this fridge hold and where and what kind should I...
this sounds like an r.v. fridge these are absorbtion cooling units and do not use freon. check the freezer and fridge compartments for an amonia smell if none check the burner heat exchanger for yellow staining if none there may be an air lock or blockage in the cooling unit somtimes cured by burping the fridge rotate the fridge in one direction untill up side down bang the coils on the back with a rubber hamer until gurgiling stops let sit for a night rotate to top in same direction bang coils again and let sit level start fridge and check for cooling if none it is time for a new fridge.
Mar 01, 2011 | Refrigerators
I want to know wat kind of ac freon my expadition
It uses the 134 A which is a replacement for freon, but is not freon. It is supposed to be more environmentally friendly, but is not as efficient when it comes to cooling as the old Freon 12. It is illegal in the US for you to have freon in your possession, only authorized shops are allowed to have it and install it.
Jul 25, 2010 | 2003 Ford Expedition
Added freon to ac and car will not cool
Needs to be checked for a freon leak, best way to do this is to recharge and add dye, with a uv light you will be able to fine the leak, most auto parts sell the dye, and the flash light you will need to fine the leak, good luck.
Jul 08, 2010 | 1999 Oldsmobile Alero
Put freon in compressor and for three days it cools after that the air is hot
It sounds like you have a small, slow leak. I would get a leak detection kit that includes dye to put in the system, and a light and glasses to find the leak. Kind of sounds like an O ring leaking.
May 17, 2010 | 2000 Dodge Durango
Dcr34w model dose not cool at all what kind of freeion do i put in it
Refrigerators do not 'use up' freon. If your refrigertor needs freon (which is VERY unlikely), it's leaking.
You don't give much to go on, so it's next to impossible to determine your problem. But my advice is to NOT waste your money on freon. There's a 99% chance it's NOT your problem and if you're not a licensed HVAC technician, you probably shouldn't be fooling with the refrigerant anyway.
Aug 27, 2009 | Refrigerators
My 1999 GMC Jimmy's AC is not cooling as well as it should. It did this a few months ago and I put some freon in it, seemed to help the problem, I tried it again a few weeks ago and this time it didn't...
This Could be And is Normaly Caused by the ORFICE TUBE Getting Clogged up it Must Be Replaced and FREON Replaced R-134A is the FREON Used in this System, The Age of your Vehicle is My Clue that this MAY BE Your Problem
Aug 12, 2009 | 1999 GMC Jimmy
1999 ford escort and the A/C stopped
Have the AC compressor checked.
Jul 17, 2009 | 1999 Ford Escort
Dometic Rooftop RV Air Conditioner Logo
168 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
