Question about Bissell SpotBot Hands-Free Compact Deep Cleaner - Silver
We have a spot bot we inheritied without a users
We have a 5-6 yr old spot bot we inheritied without a users manual- it doesn't seem to be spray much cleaning solution. Is there a place we can download a manual so we can try to problem solve. dabenroth@abenroth.org
  • 4 Answers
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Posted on Aug 30, 2010
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Need bissell spot bot oners manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 04, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
I need an instruction manual or booklet
I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
Need a Bissell Spot Bot Manual
You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Clogged spot bot
There is a very small, white water filter (approx. 3/8" in diameter/ 1/8" thick) inside the "seat" where the solution tank connects to the machine itself. Could very well be your problem if you are in a city environment, or any other situation where hard water is present. This is a very easy fix; discovered it when my wife experienced the exact same problem.
1) Make sure other causes have been eliminated, such as clogged nozzles, etc. (Refer to owners manual.)
2) Ensure that the solution tank is indeed seating properly with the machine, (a few small bubbles rise from the connection once made.)
3) Remove solution tank. With needle nose pliers or a very small screwdriver, GENTLY remove the white filter from the black, movable "seat" connection on the machine.
4) Run the machine on manual (without the filter) to determine if this is indeed your problem. (Don't run for an extended period of time this way if this actually is your problem. The filter is there for a reason!)
5) Simply wash the filter gently between thumb and fore-finger. Vinegar may be used, but simple tap water works as well. If clogged, you should feel grainy, hard water type scale/ lyme build-up when cleaning the filter.
6) Recycle the original filter or replace if necessary. (It would be very easy to make a new one without going through the hassle of dealing with OEM parts or Bissell. Just go to your local hardware store and they should be able to help you out with no problem.)
Voila! Spotbot works again.
Hope this helps!
Dec 16, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Trouble with Spotbot
My problem wasn't a problem with a new unit. We have had ours over a year and it has been flawless up until a few days ago. Ours stopped pumping cleaner for both the manual hose and the automatic section. Other solutions of priming the pump described make sense, but that was not my problem. When I would press the manual hose button a very short squirt of liquid would occur and then nothing. When I looked at the receptacle for the cleaner tank on the Spot bot side, there was a gray fuzz in there. I tried cleaning that with an old toothbrush and it came right out. It was a filter of some sort. It was gray on one side, black on the other and about the size of a dime. I guess over time the filter has gotten clogged and didn't allow a full flow of liquid. I removed the filter and put the tank back in. The unit works perfectly. I am going to try to clean the filter, put it back in and see if the unit will work. If not, the filter is history.
Jan 14, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Hands-Free Compact Deep Cleaner - Silver Logo
103 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
