Question about Refrigerators
It stared to make noise sound like fan hitting something and it stop runing,the freezer side has frost on the inside back wall
    President:
  • 3,773 Answers
That sounds like a defrost problem
check
Defrost Timer
Defrost thermostat (at the top of freezer coils about like a quarter
Defrost heater
Posted on Jul 30, 2010
Fridge verynoisey when fridge door is shut, quite when opened. now inside fridge getting warmer. where is temp control located?
Hi, Sounds like the evaporator fan blade is hitting something. Probably frost that is building up behind the rear freezer wall. Can you see fros on the rear wall? The fan shuts off while the door is open, so that is why is quiets down when you open the door. I hope this helps locate the noise. If I can assist you further, please let me know. I an help you with the defrost problem if there is frost building up.
Thank You, Vic
Apr 23, 2011 | Refrigerators
My Viking Freezer is three years old. The problem is the constant roaring sound it makes. No one can sit in my kitchen, family room or living room for very long before the noise from this freezer gets on...
There are several fans on your unit one on the top with the compressors, one inside the freezer, and one at the bottom. If you open the freezer and the noise gets louder or stops then you know it is the evaperater fan. Sometimes the bearings start to go and they make louder noise. Also check on the back wall for frost you could have a frosting problem and the fan blade is hitting on the ice
Oct 23, 2017 | Viking 15.9 cu. ft. Upright Freezer...
I bought a used whirlpool eed 251mm and it started making weird noises from the freezer section like a fan but it's really loud and horrible sounding what could this be?
Sounds like the fan is hitting something . Did this happen when you first plugged it in or after a week or so? Alo is there frost on the back wall of the freezer?
Nov 12, 2010 | Whirlpool Refrigerators
Top section not working
If there is a lot of frost build up on the back wall of the freezer section you are having a defrost problem and the coils behind that wall are filling up with ice restricting air flow and letting fan blades hit it. If not a lot of frost the evap fan motor is going bad which is also located behind the freezer wall. Good luck.
Feb 24, 2010 | Refrigerators
Hot Point rattle noise after it runs sounds like noise is coming from the back near the top . refrigator model # CTX21GAXSRWW
Hi the sound come from the fan it is locate inside the freezer behind the back wall.
you can open the back wall and check if the fan hit something.. some times it hit ice ..
let me know if you need more help.
Jan 12, 2010 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
GE Model # GSS20IEMBWW Refrigerator is making a vibrating sound in the back that stops when I open either door, but as soon as the door is closed, the noise starts back. Also, there is a lot of frost in my...
the inside fan that blows air from freezer to fridge side located on back wall either stuck has build up of ice or some debris is stopping or slowing it down open freezer door and look at back for fan remove cover and or frost covering hold door switch and look and listen to fan if labors or just hums remove and service or replace
Oct 14, 2009 | GE Refrigerators
09 recall now it won't stop running
If it won't stop running then it should be too cold. If it isn't then you are having either a frosting problem that is usually indicated by frost build-up on the back inside wall of the freezer, or you have something else going on which could be fans, one in freezer, one at compressor, bad pumping in the compressor, or loss of refrigerant(gas). Check for the frost and listen for the fans or air movement in back then you will probably have to call a technician. Good luck, AJ
May 22, 2009 | Maytag MZD2766GES Side by Side...
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
