Question about HP Officejet Pro K5400dtn InkJet Label Printer
Black printhead has stopped passing ink over small section.
I have an HP Officejet Pro K5400dtn, about 2 years old.
On text documents, a fault appeared whereby part of the print was missing as a horizontal blank strip at regular intervals down the page, as if a section of the print head had been blocked with dried ink.
Print head cleaning routine had no effect. Taking the print head out and placing on damp paper towel bled ink from the head apart from a small section which did not clear despite repeated attempts.
Assuming a faulty print head, I purchased a new print head which performed perfectly for several pages. The following day however, the same problem re-appeared at the same position in the new head, as if some fault in the printer had caused the print head to stop working over this small section.
As the print head cost about half the cost of an equivalent new printer, I am not amused.
Could you help please.
    Problem Solver:
  • 18 Answers
As you have already try with the new printheads and the issue still persist then the issue is with the printer hardware so the printer has gone defective
Hardware issue
Posted on Jul 31, 2010
Testimonial: "Thanks for your comments, though I was hoping for a way round it. Looks like a new printer after all."
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
One of the colours, Magenta, is indicating it is out of ink even when the cartridge is brand new. I have tried two new cartridges with the same result. when I turn the printer off then on again the light...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today. That particular printer has both ink cartidges AND PRINTHEADS. The problem you are experiencing is from the printheads. You should replace them. You can see more about cartridges and printheads here, including a video:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00844061&tmp_track_link=ot_faqs/top_issues/en_us/c00844061/loc:5&lc=en&dlc=en&cc=us&site=null&key=null&product=3311754&lang=en
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today. Don't forget to vote. 4 thumbs up please.
Jan 20, 2011 | HP Officejet Pro K5400dtn InkJet Label...
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
May 26, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Alignment failure
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Thanks, PREM
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
K5400dtn - paper feed and on buttons flashing - won't print
This usually the indicator for a paper jam or similar.
You need to check over the printer for any scraps, jams, etc.. that are stopping the paper or printhead from moving normally.
You also need to check for any lids or doors open and make sure that the duplexer in the back is locked into position properly.
I had to search hard but the flashing lights troubleshooting guide is available here on the HP website.
Feb 21, 2009 | HP Officejet Pro K5400dtn Printer
How do i install the printheads
Hi Theresa:
Have a look here for the guide to installing the printhead, its the section below installing the ink cartidge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&cc=uk&lc=en&dlc=en&product=2512008
Jan 31, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
K550 air in ink feedlines
I have had this happen a couple of times and have cured it easily. It has only happened with the black with me. It seems to be caused by air in the ink feed line. With the printer switched on open the top cover and hold the resume button for 5 seconds. The printheads should move to the left and you may be able to see air in the pipe(s). Remove the printhead of the offending colour(s) then insert a syringe with the plunger fully down into the rubber that the printhead connects to. Draw up the syringe plunger to draw ink/air through until you can see no more air in the pipe. Replace the printhead and close the cover. The printer should now do a calibration with the offending colour hopefully now working.
Jan 22, 2009 | HP OfficeJet Pro k550 Printer
HP Officejet Pro K5400dtn InkJet Label Printer Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
