Question about Lexmark C534dn Color Laser Printer
I keep getting 144.12 service motor error message.
I came into the office this morning and this message was on the printer. Unable to clear message. The motor sounds like it wants to start but stops right a way. There are no paper jams and the front door is closed and the paper tray is completely in. I turned off the machine and restarted with the same message.
jackboy
  • 2985 Answers
SOURCE: Paper Jam light will not go out
Please ensure that the paper ways are really clear and the doors and other deivces are truly shut Then investigate if this particular printer has a reset mode. It might not be a specififc button - but perhpas prerssing a sequest of buuton with the machine off then holding those button down switch the machine on. Some answer may also be on www.fixyourownprinter,com
Posted on May 22, 2007
SOURCE: Error - Paper Output Slot
Guest Update for MP830 on Feb. 9 "Paper output slot" issue solved. As a last ditch effort before buying another printer...(I had tried all the fixes on fixyourownprinter.com), I carefully inspected the paper feed area at the back of the printer (right back side where the verticle feed tray is). I was trying to determine the cause for a brief "paper like" flapping noise when the rollers turned. Buried beneath the large drive wheel was a piece of plastic wrap from an ink cartridge....I plucked it out with a dental pick and NO MORE PROBLEM!!!! Printer works fine. Goes to show there really was a problem even though the paper fed fine.
Posted on Feb 10, 2008
Maanita
  • 1142 Answers
SOURCE: Lexmark T630
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
Posted on May 30, 2008
  • 4 Answers
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Paper jam
Check the inside of the machine, and try unplugging the power cord for ten minutes first.
Sep 11, 2008 | Canon MX300 Office All-In-One Printer
I keep getting error 50 or error 51 and the screen says unable to print. I have followed the instructions of customer service and cleaned the coding band and checked for paper specs to no avail. I...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Sep 24, 2010 | Brother MFC 490cw Color Inkjet...
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
UNABLE TO DO ANYTHING
Give it back to a service dealer. If the machine is guarantee brother will repair it for free. Service partner can be found on the homepage of brother of your country.
Nov 10, 2007 | Brother MultiFunction Center MFC-440CN...
Lexmark C534dn Color Laser Printer Logo
125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
