Question about Samsung Televison & Video
The frontlock of my Samsung TX-20C5 is avtivated and I can not deactivate it, I have tried holding down various combinations of buttons but nothing happens, I lost remote control, any idea what should I do? Thank you Shahida
  • 10 Answers
SOURCE: Combination TV/VCR will not work from original remote.
try stripping your old remote and cleaning it, i find cleaning the contacts on the pcb and the buttons themselves with aftershave is the best
Posted on Feb 26, 2007
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
chipsandnuts
  • 70 Answers
SOURCE: i'm having problems getting my swa-4000 system to
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 03, 2009
vortash
  • 431 Answers
SOURCE: having same problems,nothing works...tried holding
Hi I am Vortash most people forget that the batteries supplied with most cameras are not of supreme quality and after a short time will stop charging .. true the indicator says they are charged as they are shorted out but in actual fact they are deader than the DO DO's , the cheapest option before you think of a repair dealer is to eliminate this by getting a new set of Ni cads and even if it isn't the fault you have at least a spare pair for your next camera .. regards Vortash
Posted on Jul 13, 2009
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
Tip
Diag mode
Holding down "video 1" and power will clear the config
Holding down "CD" and power will trigger test mode (use a and b to scroll through tests various buttons do different things
Holding down "display" and power will give you the firmware, pressing "video 1 while on version gives you model
on May 22, 2008 | Onkyo TX-SR502 Receiver
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
My Galaxy wont turn on after trying to upgrade the firmware
turn your phone off
hold down the volume up button + menu+ then push the power button, this will take you into the boot menu where you can restore your phone.
if those key combinations do not work, try holding both volume buttons, then pushing the power button.
there are variations of these key combinations but i believe one of these two above is correct.
May 04, 2011 | Samsung Galaxy S GTI9000 Smartphone
No idea how to turn on speaker phone on my juke
the samsung juke has a very paticular button on the LEFT Of the Number "0" wich is "#"
you hold down for three seconds while your on a conversation ad easy as that you have your phone on speaker to deactivate speaker mode just Hold down the # and you deactivate it
Jun 15, 2009 | Verizon Communications Samsung Juke Cell...
My button menu in my monitor is locked (model 2233sw) how do I unlock it . mavis
Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment lock function.
Apr 26, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Deactivate silent mode
first, if ita an alltel hue, the one that came with three different cases, make sure you knoe your unlock code which will either be 1234 or 0000 unlesss you've changed it. then try holding the * button if that doesnt work then try holding the # button. if that doesn't work try turnin the volume up on the side.if none of those work go to settings, then sound settings.
Apr 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Shr-1040, password fail
mode key + ch2 hold down 10 seconds factory reset password to 4321
Aug 08, 2008 | Samsung 4 Channel Dvr
Samsung 731N Auto Adjustment
Hold menu button for 5-6 sec.
Enable od disable this funnction.
Nov 18, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Televison & Video Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
