Question about Samsung 906BW LCD Monitor
Samsung 906BW failure. Screen is black; Power indicator blue and flashing. Worked fine the day before, Alt monitor works on same desktop (Win Vista Home Premium on Gateway DX4200-09/AMD Phenom 9150e Quad-Core 1.80GHz/4G/64bit). Any ideas? Hardware failure?
  • 11,361 Answers
Try it on another PC first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
I have a Dell Dimension 3000. Worked fine until we went to turn it on one day and the monitor stayed black. I'm assuming it's the video card that's the problem. I need to know what card is compatible. ...
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The links in that article will allow you to determine where the failure is on you system (The power LED indications and the Diag LED indications on the back of the system)
Post back with the indications of the POWER and DIAG LEDs on the tower if you need more detailed instructions.
Feb 12, 2011 | Dell Dimension 3000 PC Desktop
Samsung 906BW monitor wont turn on, power switch
rommelnmariv, 906BW will need to use warranty or if you are not a tech with soldering equiptment then unit will need to visit a tech to be evaluated for it's Black screen or It's Blank n Black screen problem. Read my older fixya responses (late 2009) and follow all links. Yes, some of these can be fixed-up (DIY) for under $10. Read my fixya profile for about an hour !!! Maybe you will ask your 906BW " What Brand of capacitors do you have inside you??" Bye for now. 12fixlouie
Mar 27, 2010 | Samsung 906BW LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SynchMaster906bw. Screen is black. Power button flashes.
This is 2007 monitor, time to look for bad caps in the power supply first, the problem acn also be in the inverter circuits, or bad lamps. Open it up and post back so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Samsung 906BW LCD Monitor
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
Well heres the story my sister made the screen fall on the floor one day (it fell on a very soft rug) every thing worked fine no problems but then a couple months later it started with this doesnt wana...
bamboboy, Stop yelling at your sister! ! ! If it worked fine after falling to the floor then there is something else wrong! First Prove that the pc works with a KNOWN GOOD monitor. Next, you may want to do the flashlight test with your BAD lcd monitor. Reconnect monitor to an already fully booted pc with the WIN-desktop screen showing. Then and only then turn on your LCD monitor and note what happens. If still black screen is what you see, then shine a bright light about 1" from screen and look very closely to see if the desktop is being displayed even though the screen appears BLACK. If the power supply is only partly bad you may see the desktop. I suspect that you have a power supply problem from your description. You should visit YOUTUBE and search for video clips of LCD monitor disassembly and typical repairs of units that have similar BLACK screen symptoms such as yours. You need to read more posts on fixya that I and others have made on other brands of LCD monitors that have same symptom. You will find plenty of them!! Get back to me after doing test and some more research. I'm louie12fix on fixya or lmistyrel on aol.com Bye for now.
Oct 06, 2009 | Computers & Internet
Monitor cold start issue only as #2 monitor
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
May 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Power Supply for Samsung 906BW
Of course there is - but are you willing to pay for it? Check for it on google and see if the expense is warranted.
Sep 23, 2017 | Samsung 906BW LCD Monitor
Black lettering has red or green highlights
Try turning on cleartype if you are using Windows XP. 1. Right click on the desktop and select 'Properties' 2. Select the 'Appearance' tab and press the 'Effects?' button 3. Check the box for 'Use the following method to smooth edges of screen fonts', then select 'ClearType' in the dropdown list 4. Close the Effects dialog by clicking 'OK' and click 'Apply' to complete the process
Jun 19, 2007 | Samsung 906BW LCD Monitor
Samsung 906BW LCD Monitor Logo
347 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
