Question about Forfex FX 759 Hair Trimmer
Won't cut I took the blades off to clean them and put them back on and now they work but don't cut. Don't know if I put them on too tight.
  • 76 Answers
You may have cleaned them off too well. They do need some lubricant to cut properly. You can find oil for shavers at hair salons and beauty supply stores.
Posted on Aug 05, 2010
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Aug 06, 2012 | Makita Bare-Tool BSS610Z 18-Volt LXT...
How do i grease black and decker 16' hedge trimmer
I tried hand sharpening the blade (with a file) with everything assembled, and I ended up with all sorts of cuts and scratches because it was so awkward. The work space is just too tight! Today I took the whole thing apart - put the blade in the vice and went at it again. It took 2 special screwdriver heads (6-pointed star-like design), and a 11/32 wrench to get the top screw off (used some clamp-down players on the other side to hold the nut). But I was able to clean everything, polish icky surfaces up with steel wool, and lubricate well before reassembling. There are a few washers (6) that you absolutely need to know where they came from and get them back in the same place -- but it's not rocket science. Just keep everything together so you don't end up with spare parts . . It took me 2 hours from start to finish -- part of that was figuring out how to disassemble the unit. But it worked like a charm! I'm pumped. Next time I'll have some motor grease so I can grease the motor while I have it exposed. I'm a weakling woman and my shoulder is killing me after all that effort - so maybe I can find a girding wheel for next time. But that kinda scares me cuz a wheel cuts so fast. One post suggested a dremel tool, but (since I don't have one) I think a regular grinder that goes on a drill could work if you are careful.
Mar 08, 2012 | Black & Decker 16Inch Hedge Trimmer
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
My T-outliners are running correctly but they are not cutting even the smallest but of hair and they are pulling. I have adjusted, cleaned, and examined them thoroughly and cant find a problem, they are...
sometimes the blades don't align properly when we put them back together. try to re adjust the blades, they should be 1/16th of inch apart and be level, also makes sure you are oiling the blades before every use, friction causes wear and they won't last as long.
Jun 12, 2011 | Andis T-Outliner Hair Trimmer
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
Hi! everyone, i wonder if someone can help me out with my overlock willcox & gibbs 515-e32-451. it won`t cut the fabrics, maybe the blades are in a wrong position, so i need to know how to adjust them...
if it can cut even though it seems to be able to reach the blade may be dull, or they may have been put into a rest position, look for a lever when you open up the machine. I'll bet if you look at you tube you find people showing how to do a rolled hem, and for that you have to disengage the blade so you'll be able to see how it gets moved
Feb 07, 2010 | Sewing Machines
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Forfex FX 759 Hair Trimmer Logo
98 people viewed this question
Top Forfex Health & Beauty Experts
Falling star
aravind shet
aravind shet
ray gallant
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
