Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
I have a Ariston Margherita 2000 AB 40 and the fabric softener compartment just fills with water and is blocked even after cleaning. Can i remove drawer in anyway and do you have any cleaning suggestions to unblock this? Have heard about white vinegar?
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
  • 353 Answers
SOURCE: Need User Manual for Ariston Margherita 2000 AB 40
Temperature control or speed control for spin
Posted on Dec 15, 2009
lancaster5
  • 245 Answers
SOURCE: Margherita AL 637 TX doesn't use the fabric
You need to you use really hot water and som citrus cleaner. Good luck
Posted on Aug 21, 2010
SOURCE: Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
Posted on Nov 06, 2010
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Jun 11, 2006 | Ariston Technologies LBE12X Ariston
Washing Machines Logo
136 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
