Question about Frigidaire GLMV168K Microwave Oven
Frigidaire microwave oven
Microwave lost all power, checked fuse but was o.k.. Any ideas as to cause and remedy?
  • 758 Answers
It could be the power supply board. What I would recommend you to do is to contact your local appliance repair shop or you can contact frigidaire...Their number is ...
1 (800) 374-4432
Monday - Friday
9:00 am - 5:30 pm EST
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Apr 24, 2008
    Scholar:
  • 150 Answers
Possibilities: open circuit, no power @ svc connection, transformer out on board, open safety limit. check continuity of power cord. if you have power to the unit through the power cord but no lights or display just keep following the voltage to the component or connection where you lose voltage. if you have power to the board and good neutral pathway from the board then the board is likely out.
    Genius:
  • 1,142 Answers
Is the micron working fine
  • Maanita Chadha
    Maanita Chadha Apr 24, 2008
    If your microwave oven doesn't seem to work at all, check these:
    Fuses
    Door switch
    Fuses
    Usually,
    when your microwave oven doesn't work it all, the internal fuse
    (thermal fuse) is blown. This fuse protects both you and the oven. When
    it blows, you need to have a qualified appliance repair technician
    replace it.
    Door switch
    If
    the fuse isn't the problem, check the door hooks and the door-release
    button. When these are broken, the door switch doesn't activate, so the
    oven can't work.
  • Maanita Chadha
    most of these cases i have seen that you would be needing a technician
  • 2,326 Answers
Check the troubleshooting flowchart from here.
Microwave has lost all power, what could cause this problem, and how to remedy?
Switch it off from the wall switch for a few minutes , then switch back on this will often reset it . if not get it repaired or replace it. don't open it your self , dangerous voltage inside.
Jul 09, 2015 | Sharp Microwave Ovens
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Went to turn on the mic and heard a pop and now no power. think i blew a fuse. changed it and same thing all over again. any ideas???
I had the same thing to happen to our microwave oven. I went and replaced the fuse in it. Power came back on. Then I tried to pop some popcorn in it. 30 seconds after it started, it made a vibrating noise and shut off. It took the fuse but not the curcuit breaker. The microwave is 14 years old. I have just come to the conclusion that there is buildup all inside the motor parts and that it needs to be replaced. The instruction manuel mentions to replace the monitor switch when replacing the fuse. Since I lost the manuel a long time ago, I asked at Lowes and noone knew what that was....I since found out that it was a safety device installed on the microwave oven so that if the door was not shut completely or was out of alignment, it would throw the fuse. Anyway, I am happy with the service we got with this microwave. It has been through several slammed doors and lots of use. We have been very satisfied with our Frigidare Microwave. It has held up well.
Oct 15, 2009 | Frigidaire FMT118E1B Microwave Oven
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
No power I checked the power outlet and I have 115V there Is there a fuse some ware??
If everything is ok, the fuse of microwave oven is located inside the unit, if you have a screwdriver, unplug the power cord and open it, you'll find the fuse
Aug 09, 2009 | Frigidaire PLMV169DC Microwave Oven
Changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Aug 05, 2009 | Frigidaire FMV156DC Microwave Oven
No power
you will need to replace the 20amp fuse above the control. also obviously fix the door switch. which can all be accesible through the control panel
Jan 04, 2009 | Frigidaire GLMB209D Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dead after power surge.
A) The fuse you change was the one on top just behind the control board? correct? Not the one on the door hinge side of the microwave. (as is is the Thermal cutout ) Then most likely took out the control board... i would also check the Capacitor and recifier let me know it this helped?
Aug 14, 2007 | Frigidaire PLMV169DC Microwave Oven
Frigidaire GLMV168K Microwave Oven Logo
113 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
