Question about Cameras
Photos are white when you put flash on - Cameras
    Brigadier General:
  • 4,090 Answers
This is caused by overexposure
Change the ISO value to a higher one or alter the settings on the wheel to make a quicker shutter speed ( click)
Please rate my help++++Thanks for udsing FIXYA
Posted on Jul 30, 2010
Camera takes blue photos
You sure you did put the camera to fully automatic? Because I don't know what model you have, I can't check the manual, to see if you could adjust the white balance. It has not much to do with ISO, but with white balance. Sure you did not select something like scene inside. or scene in tungsten?
May 14, 2014 | Pentax Optio Cameras
I have taken photos with white flash box of wine bottles and the
If that is the only problem with the photo, you can use Photoshop to change the pink to white. You will need to go to Image/Adjustment/Levels. Use the eyedropper on the right to click in the pink space to make that white.
The other option is to see if the bottles are bouncing color on to the white. You may want to tape some white paper to the sides of the bottle (out of camera view) so the bounce is only white.
Nov 11, 2009 | Adobe Photoshop 7.0 for PC
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
My Fuji E500 shows a white screen when any photo taken outside
is it on shuter speed priority setting?
like manual over ride? if so put it back on auto setting
Oct 27, 2009 | Fuji FinePix E500 Digital Camera
The flash attachment fades out photos on my Canon Rebel digital
set the flash in A mode if not set camera aperture close
Aug 01, 2009 | Canon Speedlite 540EZ TTL Flash
K880i white flashing screen
White Screen Of Death. Quite common on Sony Ericsson phones. My K800i does it every time its battery shuts off while it's on (so I try to make sure it doesn't). You need to (google terms) reflash sony ericsson phone Maybe also first backup GDFS The photos, except those on the memory card, and other stuff will be lost, I'm afraid. But good news is that your contact list can likely be saved by backing up the GDFS.
Mar 24, 2009 | Sony Ericsson K800i Cellular Phone
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Help w850i wsod
have the flex cable replaced....
Dec 06, 2007 | Sony Ericsson W850i Cellular Phone
Flashing Inverted White/Black Flash Sign - NO FLASH
brother your flash has got damaged. sorry to say this. but there is something wrong in your flash. take it to service center. donmt try t fix it by yourself. since camera is a costly one dont take risk.
Nov 02, 2007 | Canon PowerShot A540 Digital Camera
Cameras Logo
81 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
