Question about Garden
How to change to brush cutter blade on Robin NB253 Brush Cutter? There is too much space between the blade and where the clamp washer fits on to the threaded part of the shaft. I have owners manual and it does not show anything, I must be missing something in the instructions or equipment.
4 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: cannot stop the shaft from turning to remove lock
With unit in normal operating position, the operator can see the small hole on top of the gearbox. Insert a blunt ended metal dowel rod into that hole to lock the gearbox and remove the cutting attachment. NOTE: The locknut is left-hand thread.
Posted on Sep 26, 2009
SOURCE: Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Posted on Nov 30, 2009
dontbother10
  • 2220 Answers
SOURCE: hi im after the fuel mixture for a 125L husqvarna
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Jan 25, 2010
How do I fit a bush cutter blade
usually brush cutting devices go on weed wipers not chain saws,
hope this helps
Jan 15, 2015 | Ryobi RCS3535CA 14-inch 35cc Petrol...
How do I install a brush cutter on my 128LD trimmer?
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
May 12, 2011 | Husqvarna Garden
Is it possible to fit a brush cutter head to a ryobi rbc30cet line trimmer
Is it a straight shaft? If so measure the inside of the blade and fit the arbor to your trimer.
Aug 17, 2010 | Ryobi Garden
Can i purchase a metal cutting blade for my sovereign petrol grass trimmer 6102
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
May 08, 2010 | Garden
Arbor stuck on gear head/bc26
I have the same problem. Any solution?
Apr 20, 2010 | Ryobi Garden
I have no spark on my Ryobi Brush Cutter. Replaced spark plug but still no spark.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
Apr 20, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
Sep 18, 2009 | Ryobi Garden
HOW TO GET BRUSH CUTTER OFF FS 55
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
Sep 07, 2009 | Garden
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
