Question about Dell Dimension 4300 PC Desktop
Multiple failure notices on screen
I cannot get the system to run. Here are the failure messages:
Memory read/write failure @05CA1D0C, read 25C825CA expecting 25CA25CA
Decreasing available memory
Memory address line failure@ 05CB0000
read 00000000 expecting 34343434
Keyboard failure
Strike the F1 key to continue, F2 to run the setup utility (None of this would engage.)
  • 3 Answers
Your system memorey have a leackage problem, replace a new memory as soon as
Posted on Apr 24, 2008
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I get multiple error messages when trying to run01032410"
Please reboot your laptop then boot it using safe mode then uninstall the latest installation you have and then restore your operating system. Also try to check again your application if its support the kind of operating system you have in your system.
Thanks
Aug 03, 2009 | Lenovo IdeaPad S10-1208Uw Netbook
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Thanks for your initial efforts , ref dell latitude d600 laptop.
Well there is certainly a RAM related problem. You have to open your RAM Module, Clean its golden coloured edges and reinsert it properly. Then start your laptop to see if it changes anything. If everything remains same then you have to replace your RAM.
Be very carefull if you open your RAM. Consult your Manual first.
Nov 24, 2008 | Dell Latitude D600 Notebook
Still a problem
the blue screen flash and restard is actually a critical system message, but windows is set to restsrt the system on a system failure, if you want to read the message, start the computer and tap the "F8" key until a menu appears, one of the options will be "disable automatic restart on system failure" select this option and the next time it happens it will stay there.. but from what you are describing it is pretty evident you have bad ram, the long beeps you are hearing is the mainboard signalling a critical error, usually caused by ram, get new ram and i think you will have no problems
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Dell Dimension 4300 PC Desktop Logo
204 people viewed this question
Alun Cox
