Jazz JDC38W Digital Camera Logo
Posted on Jul 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer does not recognise the driver for my camera
Its a zero underwater digital camera with flash and when i have loaded the cd onto my computer ( windows XP) i plug the camera in and it says on the camera that its connected. i double click the precision 801version 2.03 icon and it opens and a pop up appears saying " Driver open fail!!" i have tried to find the driver online but havefailed please help as we need to download the pictures onto the computer
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 11, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470261
Points
19564
Drivers for the dx 8000g
If you mean the drivers to connect the camera to your computer, you should look for the CD that came with the camera. If you don't have the CD anymore, you could try the website from Sea and Sea, because there you also can download software. Perhaps they ask you to register the camera first, but having a serial number is the most they will ask.
view the link and look under support quick links.
Sea Sea USA Underwater Photography Cameras Video
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Loading cds onto computer
this just started happening to mine as well. and it loads each song onto my iriver instead of on a full CD.
Underwater digital camera
I have the software, and the book if you want i send it to you for € 20 !
I have also a problem i can not delete my fotograghs of my camera ?? Can you help me ?
Greetings,
Pascale
Jun 13, 2008 • Cameras
1helpful
Computer not recognising Coolpix camera
I think you need to install the driver for the camera..if you have the CD when you bought the camera then try running the CD and check for driver there. however if you don't have a CD for the driver.
try checking the website of the camera manufacturer...usually they have a driver available for download.
6helpful
2answers
Hanshing driver
i just bought the same camera and it wouldn't work with the cd either. i had to make sure that on the camera it was set to "pc" and that "mass storage" was selected before plugging the camera into my pc. hope this helps.
Sony dsc-w50
If you have a recent operating system, there's a possibility it will recognise the camera if youjust plug it in. If it does recognise it, it will install the correct driver and run a wizard to help you get the pictures on your computer.
Top Jazz Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jazz Camera Expert? Answer questions, earn points and help others
