Question about Maytag MAH2400A Front Load Washer
Intermittent leaking from Maytag Front Loader (MAH2400A model)
Hi I have a Maytag 24" MAH2400A front load washer that started leaking intermittently and can not figure out from where or how? I've checked the drain, all hoses and nothing, have also tried to overfill and or drain the machine and nothing. Any help or guidance would be greatly appreciated. Thanks
4 Suggested Answers
  • 37 Answers
SOURCE: Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Posted on Apr 20, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune top loader washer not filling
You have tried both a Hot fill and a Cold fill and still no water flow?
You could try going into Service Mode and turn on the water inlet valves with console commands. See page 16 of the Service Manual and see if you can turn the water inlet valves one at a time and get water to flow into the machine. Getting into Service Mode is easy to do
The Service Manual for reference. Sears Parts Direct for reference.
If still no water flow it would be time to check 120VAC on the water valve solenoids when you command them on in Service Mode. If no 120VAC present then we might have a Stuck open High level pressure switch which would disconnect 120VAC to the Control Board relays that operate to switch 120VAC to the Hot/Cold solenoid valves.
How do you feel about troubleshooting? Do you have a DVM? I have the schematic in PDF format if you need. Let me know if you want to DIY the fix......Rich
Posted on May 26, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: My Maytag Neptune FAV6800 washing machine
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Posted on Aug 06, 2010
Testimonial: "Excellent advice, thank you!"
Door will not open on my Maytag MAH2400A front load washer
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Feb 18, 2011 | Maytag MAH2400A Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag mah2400aww 3E error and it will not spin
I have this problem with my unit. Called Maytag and got blown off. Unplugged the unit for 24 hours and it reset. Ran fine for a while but the problem comes back.
Jan 14, 2010 | Maytag MAH2400A Front Load Washer
Can't get the door to unlock? Load in washer is beeping ND..not draining but after several attempts inlcuding shutting power off..still can't get the door to disengage?
In front loader machines there is a safety latch that stops you from opening the door if there is water in the machine. I think it needs power to release the latch, I am not familiar with this model.
You probaly need to drain the water off somehow.
Dec 16, 2009 | Maytag MAH2400A Front Load Washer
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
Maytag MD-24 Fron Load
HI,
Remove the front panel, take the suction hose off the pump and remove the coins and bobby pins from the pump impeller
Jul 19, 2008 | Maytag MAH2400A Front Load Washer
Maytag MAH2400A Front Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
