Question about Hayward H-series Electronic Gas Pool Heater H400
Temp on water boils in heater core
Temp on high on water boils in heater core h400 older model heater has temp dials
  • 990 Answers
This will be a water flow problem. If you have a heater by-pass it will need to be almost closed (80-90%) If the water has overheated you may need to remove the header going into the heater and replace the internal by-pass assembly.
Posted on Aug 02, 2010
Water boiling out of the pressure relief valve
1) Copy following links for troubleshoot resources:
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Problem indicates bad gas control valve thermostat.
The dial located on gas control, is part of the thermostat on gas water heater. Copper probe protrudes into water heater, and this probe contains the ECO energy cut off and thermostat. Thermostats get out of calibration, or they fail. Replacement should be done by experienced person, otherwise it is relatively simple using pdf link above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 17, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
When the burners ignite, within one minute it starts making a loud banging noise and then the HS code comes on and it shuts down. the noise continues for about 15 to 30 seconds after the burners shut...
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Jul 18, 2011 | Hayward H-series Electronic Gas Pool...
Temp guage showed extremely hot than i heard a loud phizzing sound and coolant started boiling onto my feet from under the dash
That is your heater core that has failed. Possibly the thermostat stuck closed and made the water pump build up pressure to blow your heater core. so I would change the thermostat also. The heater core is not a easy job but it is doable for someone with good mechanical knowledge. I hope this helps.
Jun 06, 2011 | 1998 Plymouth Grand Voyager
A t hot temp subaru forester 1998
A car running hot can be of many causes. Thermostat can be checked by removing and place in boiling water thermostat should open when water reachs temp, hole in hoses hoses will expand when they become hot so a pinhole will open and beome lager when hoses heat, enginge needs flushing a lot of rust and dirt in anti freeze will cause the car not to run correctly, and water pump going bad. Also heater core however I would flush engine before replaceing heater core as it may become clogged.
May 10, 2011 | 1998 Subaru Forester
Where is heater control valve on 2003 dodge ram pick up
THERE IS NO HEATER CONTROL VALVE ON THE WATER HOSES. NEW HEATER CORE. INLET LINE right before heater core hot, outlet after core look warm. Burped cooling system 5 times with engine at operating temp. Installed homade burp VALVE right after heater core outlet(high part of hose). Still no heat. Removed water pump, impeller still in good shape not stripped off shaft. Removed heater core hoses flushed water thrue the connections on the block to the water pump INLET and outlet. flushed water thrue heater core and hoses. Going to put it back togeter today. Used known good gauge to check water temp for operating temp in test. 195 f
Oct 22, 2010 | 1997 Dodge Ram 1500 Club Cab
H-series Electronic Gas Pool Heater H400: I have an H400 with digital temp control panel, th...
It is likely the keypad that has gone bad. Not difficult to replace. But you want to be sure thats what it is, as it is an electronic part, that is usually not returnable. The part number would depend on the model of the heater. Likely it is a h400idxl2 heater.
May 16, 2010 | Hayward H-series Electronic Gas Pool...
REPLACED THERMOSTATE, TEMP(FAN)SENSOR, WATERPUMP AND THE CAR IS STILL BOILING THE WATER OUT OF THE OVERFILL RESEVIOR AND NOW THE HEATER STOPPED WORKING
Your heater core has no idea if coo or hot water is passing through it. Either it flows or it doesn't. Run the engine till it is at normal operating temp with the cap removed and the front end jacked up on the corner where the fill is. After it reaches operating temp, turn it off, wait about three minutes and start it again. Turn the heater on high. Add coolant till it's full and let it run. It may overflow a little a few times but should not overheat.Make sure that you are adding a 50/50 mix as straight antifreeze will boil at a lower temp than does water. If you have any bleed ports on the engine you can open them if necessary. If the radiator is flowing properly everything should return to normal.
A partially obstructed radiator can appear to flow normally as the coolant goes around the restricted passageways. turning the heat on will never cause an engine to overheat even if it was totally plugged. Be sure there are no external obstructions as well (bugs or leaves packed into the A/C condenser or between the condenser and the radiator. It is sometimes possible for a head gasket to allow compression gasses to enter the cooling system. it will first fill the heater core, then push water out of the cylinder head passages. You can have a hydrocarbon test done at any shop to find out if this is happening. Your original problem was an overheat. Even if it was due to another problem, it can cause a gasket to fail or a cylinder head to warp or crack.
Try what I said and if that fails have the test done.
Good Luck!!
Feb 03, 2010 | Chevrolet Malibu Cars & Trucks
Heat will stay on high until turn engine off and back on
check dial switch, check valve that lets water run through heater core
Aug 23, 2009 | 2000 GMC New Sierra 1500
Engine overheats when heater pipes connected
I think you could be right about there being air trapped in the system.
Or the heater core(radiator) is plugged.
Either way you need a pressurized radiator coolant pump to put the coolant in without air being trapped.
Although,i have seen it done by jacking the vehicle up high enough that the radiator was now higher than the heater core level, and then the coolant was put in.
But this is dangerous to try.
Jan 29, 2009 | 1999 Ford Escort
Cold Ait from heater ducts
u might want to check the blending doors that control ur ac and heater flow they tend to get stuck sometimes
Oct 25, 2008 | 2000 Ford Taurus
Hayward H-series Electronic Gas Pool Heater H400 Logo
106 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
