Question about HP Pavilion dv6-1030us Notebook
MY HP DV6 1030US WILL NOT TURN ON. IF I MANUALLY HOLD THE START BUTTON THAT LIGHTS UP BUT AS SOON AS I LET UP ON IT NO GO NO GLOW. NICE TO KNOW HP HAS 12 MONTH WARRENTY AND MINE IS 15 MONTHS OLD :( ANY SUGGESTIONS?
  • 788 Answers
SOURCE: wireless mouse is not working. computer says the
Sorry to hear about your HP problems.
Your wireless mouse or touch pad controls are located on the touch pad and if you look at the top right of touch pad, when the mouse is on, it will shine blue, when off, it will shine orange.
Simply hit the push button on the top right of your touch pad to activate.
Hope this information has helped you. ??
John Ray
Posted on Jul 13, 2009
  • 226 Answers
SOURCE: HP Pavilion dv6-1030us PC Notebook,
they should be under little stick buttons or a rubber piece stuck in there where the screw is
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Posted on Jul 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: How do I replace a keyboard on a HP dv6-1030us
Here is the manual....
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
Posted on Sep 27, 2009
  • 280 Answers
SOURCE: my hp pavilion dv6-1129tx note book fan is making old noise
Use the following link to locate a Specialist near you
HP Specialist Search
Posted on Feb 20, 2010
  • 1082 Answers
SOURCE: how do i replace the lcd screen on hp dv6 1030us i
Generally the keyboard is removed first then you can tackle the LCD. I'm surprised you are replacing it as LCDs are expensive.
Posted on Aug 13, 2010
Is not working more
Switch the printer off.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Nov 04, 2012 | HP Computers & Internet
Change HP printer language from japanese to english
  • When the printer is on, hold the "GO" button for 5 seconds. The printer will be reset.
  • Turn the printer off, hold down the "Cancel" and then turn on the printer while continuing to maintain the "Cancel" button, once the lights come on release the button. The printer should then be reset.
  • Turn the printer off, hold down the "GO" and then turn on the printer while continuing to maintain the "Cancel" button, once the lights "error" light release the button. The printer will then reset and start again in a state of "Ready."
Dec 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Glo plugs don't seem to be getting hot when I hold the button down ... it will however start with star ya bastard ... once the enging is hot it will start no problems
GLOW HAS TO BE WORKING.BECAUSE ENGINE STARTED.GLOW PLUGS ARE USED ON COLD START UPS.GLOW PLUGS PREHEAT THE AIR IN COMBUSTION CHAMBER SO DIESEL FUEL WILL START TO BURN ON START UP.WHEN YOU TURN ON IGNITION SWITCH THE GLOW PLUG LIGHT WILL TURN ON FOR MINUTE UNTIL PREHEAT DONE.GLOW PLUGS WILL STAY ON UNTIL THE COOLANT TEMPERATURE GET OPERATING TEMPERATURE.THEN THEY TURN OFF.
Mar 21, 2010 | 1997 Nissan Pickup
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
A red light is on my margaritaville machine and have to manually hold switch to shave ice. what can I do to fix?
As soon as I turn my tahiti on I get a red flashing start button is this normal? And I also have to hold the button to mix?.
Aug 02, 2009 | Margaritaville Frozen Concoction (DM1000)...
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
May 11, 2009 | HP LaserJet 3330 All-In-One Printer
Service engine soon light on in 2004 buick rendevous after accident. no codes given. turns on when engine starts.ran scanner- no codes... had to reset everything after car repairs. told not related to...
oh thats the change oil light expect it every 3500 to 4500 miles they glow.. you can usually reset it by holding down the trip button with the car off and then turn the key to the II position where everything lights up
so read me >>>>>
Buick Rainier 2004-06, Buick Rendezvous 2002-05 w/o (DIC) Driver Information Center
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Buick Rainier 2004-05 wI (DIC) Driver Information Center
The DIC display is located on the instrument panel cluster above the steering wheel. The DIG buttons are located on the steering wheel. Press button with the gas pump symbol to display engine oil life. Press button with the arrow symbol to reset engine oil life display.
Buick Rendezvous 2002-06 wI (DIC) Driver Information Center
To reset Service Reminder Indicator, turn ignition on with engine not running. Press the MODE button until DIC reads oil life left hold SET to reset. Press and hold the SET button until 100% is displayed. You will hear three chimes and the change oil message will go out. If the CHANGE ENGINE OIL’ message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
May 08, 2009 | 2004 Buick Rendezvous
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
HP 2200 -
Cold reset:
4. Release GO.
NVRAM Reset:
4. Release GO.
HP 5P & 6P
Cold reset:
Reset the NVRAM:
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
HP Business Inkjet 1200 --all lights ablaze, printer won't reset
  • To reset the network configuration follow the instructions below:
    1. Press the Configuration Page button once.
    2. Press the Resume button three times.
    3. Wait for about 20 seconds and then press the Power button to turn off the printer.
    4. Disconnect the power cord from the printer.
    5. Wait for about 20 seconds and then reconnect the power cord.
    6. Press the Power button to turn on the printer.
  • Not sure if this will resolve other issues, but it's the only reset I know of.
    Oct 05, 2008 | HP Inkjet 1200dn Printer
    HP Pavilion dv6-1030us Notebook Logo
    727 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
