Question about HP Color Laserjet 3550 Printer
Left side of documents print very light - HP Color Laserjet 3550 Printer
  • 44 Answers
This could be a problem with the tonner or the configuration of ink... in both cases try with another catridge or tonner, if the problem solves then is because the cartridge or tonner no have enough ink to print
...... if the problems persists maybe could try verifing the configuration of your printer or re instaling the printer too...
Posted on Jul 30, 2010
Why does my Deskjet 1050A printer chop off 1 on the left side of a document I am trying to print?
If the only thing that you REALLY need to print is the last couple of pages then why not just print them only and correct the margins if need be. just a thought.
Dec 07, 2015 | HP DeskJet Office Equipment & Supplies
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
When printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
My printer only prints the left side of my document
First try printing directly from the PC to the printer without using the JD. If the problem persists, then factory reset the print server and reinstall the appropriate print drivers onto it before reconnecting to it.
May 24, 2009 | HP JetDirect 300X Office Connect...
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
