Question about LG DH30 GoldStar Dehumidifier
Need fan motor. Were can i get one - LG DH30 GoldStar Dehumidifier
    Problem Solver:
  • 10 Answers
Maybe at appliance parts co 330 453 8077
Posted on Jul 31, 2010
AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Dec 30, 2009 | Amcor Dehumidifiers
The fan inside is having a hard time rotating...starting to smell. what gives?
If the fan motor is quite hot to the touch when it is running and the smell is like something burning and the fan blade isn't rubbing on the housing then the fan motor bearing are most likely worn out. If that is the case then the fan motor is bad and needs to be replaced.
Nov 17, 2009 | LG LHD65EBL Dehumidifier
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Fan motor doesn't run.
You're gonna have to do a little work but there should be and electric motor shop in any large city that can rebuild YOUR motor. (found quite a few listed under <electric motor> in the GR,MI yellow pages)
Jun 06, 2009 | Edison 40 Pint Dehumidifier
Fan motor not working
Hey, I need to buy a new fan motor and will share the install info once I install it myself. My question is: Where can I buy a fan motor for this unit?????
Jun 24, 2008 | LG LD65EL Dehumidifier
Compressor runs but fan will not come on.
Disconnect the motor leads for the fan motor, check the resistance through the motor when an Ohm meter. If you get no reading on the meter the motor is bad and needs to be replaced. also check the motor by rotating the fan. If it rotates with resistance the bearings may need lubrication. If it is a sealed bearing motor and no points for lubrication are there, replace the motor.
May 26, 2008 | Goldstar DH304 Dehumidifier
Fan not working
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Mar 22, 2008 | Kenmore 54501 Dehumidifier
Fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Oct 23, 2007 | Comfort-Aire BHD-651 Dehumidifier
LD65EL Dehumidifier rumbles and has poor air flow
Sounds like the bearings have failed in the fan motor, & the rotor is rubbing on the stator. You mentioned end play in the shaft, check for cross play. There should be no perceptable cross play, any found indicates a need for a new motor.
Jun 20, 2007 | LG LD65EL Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
66 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
