Question about Roxio Easy Media Creator 9 Suite (227100) Full Version for PC
I've had a lot of problems with my laptop and have had to restore it and I was trying to put Roxio 9 back on and it ask for my CD Key which I no longer have. I also have it installed on my desktop computer but still couldn't find the CD Key. Roxio couldn't help me because I didn't purchase it online but in a store. Please help me. I don't want to have to buy another Roxio 9 at this time. Thank you so much.
    President:
  • 2,571 Answers
Try Belarc advisor, it picks up all your programs and keys
Posted on Jul 30, 2010
    New Friend:
Thanks for your comments. I upgraded to Roxio 10.
all is good
Posted on Nov 06, 2013
Program stops working after burning one cd and won't work again for awhile
i have probs some times so i always go back to this Burnaware Pro.
i have uploaded this for you.. its easy to use.
https://www.4shared.com/s/fLOd2-Rptca just install its the full pro version no key need.
Jan 19, 2018 | Roxio Easy Media Creator 9 Suite (227100)...
I lost my CD key for Roxio easy media creator 9.0. Need the CD key.
You can try this 61-UTR95-98K8L-95HU7
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 02, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
I have lost cd key for Roxio Easy Media Creator 9
Try this 61-UTR95-98K8L-95HU7
Feb 27, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Install a roxio cd into my laptop
You need a replacement CD drive most likely.
The 5300 can be swapped for almost any generic laptop optical drive. I would pick one up from directron.com or geeks.com they have new drives cheap.
Then just unscrew the plastic mounting rails attached to the side and back of the drive, swap them over to the new drive and go!
Dec 20, 2007 | Gateway Solo 5300 Notebook
Markmakkie@hotmail.co.uk
u already paid for the software so dont use any pirated key .. just goto roxios website http://www.roxio.com/redirectmyaccount
Dec 02, 2007 | Roxio Easy CD & DVD Creator 6...
Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
Nov 07, 2007 | Roxio Easy CD & DVD Creator 6...
Roxio Easy Media Creator 9 Suite (227100) Full Version for PC Logo
270 people viewed this question
Top Roxio Computers & Internet Experts
Marvin
Marvin
Alun Cox
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
