Question about Refrigerators
I changed the thermostat and heating element on my maytag side by side refridgerator(MSD2766GEB) about ten days ago, itseemed to be working fine the fans are workbut today the coil was iced over again could it be the defrost adaptive and if so how do i check it to confirm if its good or bad?
  • nicehitsam Jul 30, 2010
    thanks as always fixya is right on the mark I found a burnt spot on the Adaptive Dfrost control.
  • Alisa Wilkerson Aug 30, 2012
    Replace also the adaptive defrost board.
  • 4,323 Answers
Hi
The frost on the coils again indicate that there is some issue with the defrost system. As you mentioned that you have changed the Thermostat then the other thing to check for is Adaptive defrost control. This can be checked by opening up the control assembly. Snap out the adaptive defrost to release the clamps located near the assembly. Now, remove out the whole assembly and take out the 4 prong plug from the Adaptive defrost control. You can check out part # (Adaptive defrost Control system, part #13 in diagram)---
If the timer is burnt or the connections are cut then you'll need to replace the timer. However, wheYou can buy the part from this link---
Adaptive defrost Timer
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 30, 2010
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Refridgerator will not cool. Freezer works fine. Noticed a pool of water on floor then started to cool again. after a few days quit cooling.
Check the water drain hole in bottom of unit. If plugged water cannot get to catch and pan and evaporate with the heating element.
Aug 25, 2011 | Maytag MZD2766GES Side by Side...
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
Freezer working, but refridgerator is not cold. The fan works.
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
.g_thread_answer { overflow:visible !important; } X Leave your feedback for the Expert! Write a testimonial (150 Characters max) Submit Testimonial Back
Was this helpful?
Rating helps you get better solutions
Somewhat Helpful
Jun 08, 2010 | Maytag MBB2256G Bottom Freezer...
Dryer doesnt work, worked fine a few days ago, checked the circuit breaker, it's fine.
check the element, thermostats, and themal fuse if not heating...
Feb 08, 2010 | Maytag Dryers
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
2008 maytag refridgerator tripping my breaker
take it back as it's a fire hazard.  Get a replacement.
Apr 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
