Question about Jl Audio 300/4 Car Audio Amplifier
I have JL300/4. My front speakers starting popping and sounding bad, so I replaced them. When I turned the reciever on to listen to them, the right speaker started smoking. Could my amp be bad? The rear speakers still play.
  • 58 Answers
Well its not a good sign when your equipt starts smoking . Chances are that at least one channel of your amp is bad .But your real quest is to find out why the amp smoked in the first place. Chances are you have a shorted wire or speaker or both. Best way to check is is to check the wire with an ohm meter, if it reads less than 4 ohms you have a short .Next disconnect the speaker and check the wires to ground and measure the speaker. You need to do this before you repair or replace your amp or you will have it happen again. Noow it is possible the amp did fail on its own but the chances are it had help.
Posted on Jul 30, 2010
Have a random popping sound coming from car speakers. Sometimes its just from the front right door speaker sometimes its from all the speakers, pops range in loudness levels, the loudest pop comes from the...
Is it after market radio? Check connections from radio to speakers and at the speaker(s) Door slamming knocks wiring loose. Also bad antenna lead can do it also since most radios get ground from antenna.
Feb 25, 2011 | 2001 Honda Accord
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
There is a popping sound coming from the front end of my car when I accelerate but only when my car is moving, not when it is parked. Any ideas?
Sounds like your half shafts are going bad. Does it make this noise when turning left or right? If it does your half shafts have gone bad.
May 06, 2010 | 1992 Subaru Legacy
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Yamaha sourround sound reciever HTR 5920- not working
Can you remove connection between the receiver and TV and then try ? If it still turns hums and turns off, then try disconnecting all the speakers and power it on. If it still turns off, then you have a bad receiver...Let me know..
Mar 20, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No sound coming out of Center, left and right front speakers
make sure you didnt turn off speaker set A on the reciever. cause from what i can tell from the manual you may have hit a button to turn them off. now on your reciever look below the power button on the unit itself. below that is a speaker A/B push the A button to make sure its on or the B depending how your speakers are rigged. if this isnt the problem let me know and i can help you with another solution -Nate
Jun 14, 2008 | Yamaha RX-V800 Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Jl Audio 300/4 Car Audio Amplifier Logo
105 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
