Question about Whirlpool Dishwashers
My Whirlpool Quiet Partner 111 dishwasher Model # GU2500XTPS7 control panel won't respond. There are 4 lights on, the normal wash light, heat/dry light, the lock light, and the start/resume light is blinking. I have held the heat/dry button for 5 sec. trying to unlock it and nothing happens.
  • Anonymous Mar 17, 2014
    Not heat drying. Don't think hi temp wash works either. Quiet partner v
  • Anonymous Mar 26, 2014
    The 2hour delay light is blinking
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool Gold Quiet Partner III dishwasher will not start. I have installed a replacement control board that worked for awhile. When it quit I put the old control board back and it worked for awhile...
Hi Cathy, we are sorry for the concerns. We would advise service with an authorized servicer. If you would like to schedule service please email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and model/serial number.
Apr 11, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,408 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
