Question about Troy Garden
How to replace starter rope on troy bilt tbe515 edger
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: starter rope replacement instructions for a model
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed
Posted on May 07, 2011
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Manual for singer sewing machine
is this an old leather machine?
Jul 12, 2012 | Sewing Machines
Replacing starter recoil rope on troy bilt 4-cycle cultivator
Either contact the company or Google the model number for a service manual.
Jun 14, 2012 | Garden
Replace starter rope on a tb70ss troy bilt trimmer. everything is off but the red plastic casing
you will need to flip the casing upside down and wind the pulley counter clockwise, it should be pressure on the pulley if not then it is clockwise, once you have wound it six or seven times, you will need to feed the pull rope from the outside in, there is a hole on the pulley where the rope comes through, while keeping the tension on the pulley, once the rope is through you will need to knot the end and burn the end of the knot, let go of the pulley it will wind the rope, pull on the rope a few times to make sure the knot is holding, then reassembly the unit. Hope this helps Tim
May 07, 2011 | Troy Bilt Tb70ss Gas Trimmer
How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Troy Garden
Troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Oct 25, 2009 | Garden
Troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
2,522 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
