Question about Canon Office Equipment & Supplies
Not printing displays"ink well is full" - Canon Office Equipment & Supplies
    Genius:
  • 1,478 Answers
What is the model and maker of the printer? if i can know this, it help suggest solution to the question.
Take care
Posted on Jul 30, 2010
  • 1 more comment
  • gcorrea99 Jul 30, 2010
    model -BJC 2110
    CANON BJC 2110
  • Jimoh Adeleke Muyideen Jul 30, 2010
    follow the procedure below to reset your printer,
    : Remove the Cartridge
    2: Unplug the AC Power Cord
    3: Close
    Front access panel
    3: Hold down the RESUME/RESET button and plug in
    the AC power cord
    4: Release RESUME/RESET after plugging in the AC
    Power cord.
    5: Press the RESUME/RESET once within 5 seconds and
    release the RESUME/RESET .
    6: Press and HOLD RESUME/RESET for two
    seconds or more and release it.
    7: Press and HOLD RESUME/RESET for
    two seconds or more and release it.
    8: Unplug AC Power Cord to set
    data
    If you need nore info try here http://canonhelp.sharewith.us
    Try soaking the print head in a shallow dish/plate of hot distilled
    water to remove any dried out ink. You may need to repeat the process a
    few times to fully unclog the print head.
Ink absorber full brothers
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Please Visit :- Printer Expert Technician Brother Printer Support
Dec 26, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Wont print. solid red ink light. wont display ink levels
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Nov 18, 2011 | Office Equipment & Supplies
I replaced the clear ink tank on mx7600 and the message "the clear ink is empty" will not go away nor will it print in black. The brand new Canon brand clear ink can be seen on the ink tank itself and in...
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Oct 20, 2010 | Canon PIXMA MX7600 Multifunction inkjet
I have put a new Cyan ink cartirdge in put it will not print
Make sure the cartridge is full y inserted if not will not print and it will aslo not display.
Aug 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not print
When the ink absorber is full it cannot clean. Ink box needs to be replaced by a repair shop, and the count reset.
Jul 26, 2009 | Brother MFC-3240C All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
13 people viewed this question
old marine
old marine
