Question about Boss RT-1035 Car Audio Amplifier
Car amp smokes when ground wire is installed?
  • 58 Answers
Chances are the amp was wired up wrong and you hook up the ground you are allowing an already damaged amp fry.
Posted on Jul 30, 2010
Tip
Jl 1000/1 amp problem
i tried switching my lanzar amp to my jl 1000/1 amp myself last night and as i plugged in the ground.. some smoke came up from where the ground and 12v cords meet the sub.. it wasnt much smoke, just a little. so i plugged my lanzar back in and today at lunch went to get it installed and it seemed to be hittin when i left the car audio place.. but its not hitting like it should. the lanzar hits harder. what went wrong? what does that smoke mean? how do i fix it? thanks. i am worried sick. those amps arent cheap.
on Jul 26, 2008 | Jl Audio 1000/1 Car Audio Amplifier
I have a PYLE Amp. Model No. PLA-2380. I had it installed into my car it was working great! And then one day it just stopped turning on. It is getting power, the Ground is still good, And my remote wire...
You want to verify your wiring first. Use a volt meter to make sure the power and ground are good. You can jump the + to the Remote to bypass the head unit(after unhooking the remote wire). If at any point you had your speakers short out or wires hit together it will have smoked your power supply and damaged it internally. If you end up verifying the power and remote are working right and there is still no amp turn on, measure the fuse for resistance. Should be 0 ohms. If the fuse is good, the power/remote are good, then the amp is internally damaged. Any number of things could be wrong. Good luck
Dec 06, 2017 | Pyle PLA2380 Car Audio Amplifier
I accidentally wired the 12v wire to my ground terminal, and the ground wire to my 12v terminal. A little poof of smoke and the amp won't turn on anymore. Checked my fuse and power supply, all is fine. ...
Hi
It look like you burned the power supply in the amp if the fuse is ok
there is a circuit that protect the amp and its possible that it burned
this should not be too expensive to be fixed
ecrdn@yahoo.com
Jack
Oct 19, 2010 | Jl Audio 300/4 Car Audio Amplifier
I have JL300/4. My front speakers starting popping and sounding bad, so I replaced them. When I turned the reciever on to listen to them, the right speaker started smoking. Could my amp be bad? The rear...
Well its not a good sign when your equipt starts smoking . Chances are that at least one channel of your amp is bad .But your real quest is to find out why the amp smoked in the first place. Chances are you have a shorted wire or speaker or both. Best way to check is is to check the wire with an ohm meter, if it reads less than 4 ohms you have a short .Next disconnect the speaker and check the wires to ground and measure the speaker. You need to do this before you repair or replace your amp or you will have it happen again. Noow it is possible the amp did fail on its own but the chances are it had help.
Jul 30, 2010 | Jl Audio 300/4 Car Audio Amplifier
Jl audio problem
first things first. Disconnect everything. (Though if it smokes it might be too late.) Then try connecting things back one at a time starting with power. Make sure that none of you speaker wires is connected to chassis ground. Audio ground and power ground should not necessarily connect.
Apr 03, 2010 | Jl Audio 500/1 Car Audio Amplifier
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Smoking
Gee I would think that it is kind of obvious; your amp is blown. Just because it doesn't blow fuses doesn't mean much. If you hook the power up to the ground input and the ground to the power and then turn it on you pretty much toasted the amplifier. If you don't know why the amp is smoking, but you're trying to fix it yourself, you are basically telling me that you have no business doing so. I have been an installer for 15 years and even I am not dumb enough to try to fix a bad amplifier. Do everyone a REALLY big favor; stop messing around with something that you don't understand of have knowledge about before you hurt yourself.
Mar 16, 2008 | Legacy LA838 Car Audio Amplifier
My amp was smoking and I want to know how to repair it.
The Amplifiers Positive to ground will only hurt the wire to the battery, and blow the main fuse near the battery.  Check the main fuse near the battery.
Oct 28, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Smoking Amp
yes let me see the pics my email is troublerst@hotmail.com
Jan 23, 2007 | JBL GTQ190 AUTOMOTIVE POWER AMPLIFIER Car...
Boss RT-1035 Car Audio Amplifier Logo
54 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
