Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Where can i get buffer board for my videocon plasma 42 tv in mumbai
    Genius:
  • 1,340 Answers
I have tried looking up parts for TV's and they will not sell to consumers.You have to be a dealer to get a username to see that stuff.It will have to be a repair center.Sorry and good luck.
Posted on Jul 30, 2010
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
My tv made a load pop and the picture went. I still have sound though
Ur tv have 2 long buffer boards that help the Plasma screen panel to have a backlight to produce a picture.Those 2 long buffer boards either one it is dead or both 2 long buffer boards are dead.Those 2 long buffer boards it is the causes.U must have some mechanical skills and some basic electronic skills,like to take out those 2 long buffer boards out and have test and replaces those ethier long buffer boards it is dead or both 2 long buffer boards.If u have no mechanical skills and electronic skills.Best just call and take estamate of many prices of those tvs shop in ur cities area for the best prices and pick one tv shop and get ur tv repair.
Oct 03, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I have Videocon Plasma Model, problem in plasma Panel y board panel r as per the videocon servicing centre. Part detailos are- yd 07 Samsung panel? Should i replace it or think for new TV? What will be...
IF YOUR Y BOARD IS SHORT YOU WILL HAVE TO REPLACE THE TWO Y BUFFERS THIS WILL COST TO MUCH THE EQUIVELENT OF YOUR TV IS 430 WITCH COST ABOUT 600 DOLLARD
Nov 17, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have a videocon 42" plasma TV. All other functions work, except, a vertical black band about 2 cms wide appears on the right half of the screen.
What you need is known as a "Z buffer" or "address buffer".
It is a board located UNDER the display.
Can't tell you the board number because you do not mention the TV model, but if you are up to replacing it yourself you better get to there anyway and see the model printed on the board itself.
There are usually two boards underneat in the 42'' models, sometimes three, but usually two.
You need to find the one located where the vertical line shows and replace it.
Replacement is not hard, but requires a bit more unscrewing because those boards are usually covered by metal shielding / heatsink, which usually has quite a few metal screws.
Other than that, though, it is not hard.
Mar 23, 2010 | LG 60PS60 60 in. Plasma HDTV
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a 42 inch phillips plasma, went to turn on would not turn on, repair guy said $510 to fix, buffer board / upper y board bad, where can I find and fix myself.
my advice would be to find a supply store online who sells parts for tvs, if it were me i would google the model of my tv and put in buffer board and upper y board, you should be able to find suppliers, hope this helps
Nov 18, 2009 | Philips 42PF9630A 42 in. Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
42 in Panasonic Plasma TV - 4in wide vertical black band obscures image. What is wrong, how do I fix it, and what does it cost.
take it apart and reseat connectors on bottom buffer boards if not may need to replace buffer boards on bottom of tv
Jun 07, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Electrograph DTS4225PTD Plasma TV 42"
It's Y upper buffer, also cross matches, with LJ41-02760A which is for Samsung 42 Plasma
Feb 29, 2008 | Electrograph Systems DTS4225PTD 42 in....
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
44 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
