Question about Saitek Pro Flight Yoke System Flight Simulator
Need electrical schematics for saitek pz44
I believe that the usb port power is limited to one port and a second usb port is straining the system.
    Problem Solver:
  • 5 Answers
If that is the case, a larger power supply in the computer will fix it. You don't want to try to combine them to one usb as the controls most likely map to the same parts of the usb. Also, a powered usb hub will fix the problem, and those are easier to install most of the time than a power supply.
Posted on Aug 01, 2010
Need manual for Saitek R4 force wheel
All the manuals and drivers are on the Saitek Website, very easy and straightforward to find and download what you need.
Just make sure it's plugged in to a USB port.
Oct 15, 2016 | Saitek Video Game Consoles & Games
Saitek Pro Flight Yoke Suddenly Stops working.... Usually when i switch on my pc, the yoke will also turn on as well by looking at the green light at the timer screen on the yoke....but now when i on my...
Try basic troubleshooting first, try to remove and reconnect the ps/2 and usb of the saitek pro flight, also try to put it in different usb ports to see if maybe a usb port is not working, lastly when all else fails try to connect it in another computer and see if it works.
Jan 02, 2018 | Saitek Pro Flight Yoke System Flight...
Saitek ST90 USB stick, used in Flight Simulator, working fine until earlier today, now nothing. Change the USB port (3 different ports), Win7 on 64bit system recognises the hardware, install onbaord...
If the computer is consistently picking up the Saitek ST90 and it still isn't working it could be a problem with the game rather than your stick.
Do you have another game you can test it on even if it isn't meant for it? Just to see if other games pick it up.
If they don't then I would reinstall all drivers first, if they do get picked up then your best bet might be to reset game to factory settings and if no luck then reinstall the game.
Sep 27, 2017 | Saitek ST90 USB Joystick
Unable to use my Saitex Wireless Mouse with my Vaio Laptop
You'll probably need to update your mouse & Keyboard drivers to Win7 compatible.
It should be available for free download from the Saitek website. Follow links to Support and Downloads.
May 01, 2010 | Saitek Executive PZ18AU Keyboard
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Sep 07, 2009 | Saitek Pro Flight Yoke System Flight...
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
Computer wont recognize me Saitek GH20 Headset
I have the same problem. I suspect that this headset is not USB compatible at all. It possibly only uses the USB connection as a source of power (for the vibration effect). This is a problem for me because I wanted to use the headset on a PS3. Saitek don't claim that it works with the PS3, but the claim of USB compatibility is ambiguous and misleading in my opinion.
Feb 20, 2009 | Saitek GH50 Headset
Repeating key - cause unknown
No solution here, but I'd like to second that I have a Saitek 1st gen keyboard. One day it began exhibiting the same problems that you are having. When moved to another computer it seemed to work for a month or so but then started acting up again. For my keyboard, it repeats the letters "a" "s" "m" and others. Not sure what is causing it. No spills on the keyboard and it is fairly clean.
Oct 17, 2007 | Saitek Executive PZ18AU Keyboard
Saitek Pro Flight Yoke System Flight Simulator Logo
372 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
