Question about Toshiba e400 Pocket PC
I was trying to hold one of the corners of my Toshiba pocke pc e405 togather with a glue but somehow it went inside the sacreen and since then my pocket pc does not work anymore. I mean the touch screen function does not work it does not respond to the stylus anymore. Any suggestion do I need to buy a new pockket pc or is there anything I can do to get it going. Thanks Khawar Shabbir
Mr PDA
  • 4 Answers
SOURCE: touch screen is not responding with the stylus
Try do a hard reset to your device to the deafult vendor definitions, then re-initilize the screen and this should help.
Posted on Nov 13, 2006
JustAskMe
  • 29 Answers
SOURCE: Toshiba Touch Screen does not work
Hi This may help you :: Select , Settings, System tab, Align Screen to adjust the touch screen. If the screen alignment loses calibration it may not be possible to adjust alignment using the above method. Also, here is a link that may help :: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuals-userguides-su530093-ppce400ug20030916pdf&sliceId=pdfPage_113&dialogID=6730022&stateId=1%200%206728267
Posted on May 05, 2007
JoRIck
  • 47 Answers
SOURCE: Pocke pc keeps resetting
I have 2 camcorder batteries that are totally dead. No matter how long I leave them plugged in, they aren't coming back to life.
Everything has a life span and it looks like your battery has reached the end of its life. If the e405 works on AC but not battery, then I have to suspect the batteries are now duds.
Time to go shopping on ebay!
Posted on Mar 14, 2008
male_28_cam
  • 1555 Answers
SOURCE: RAM UPGRADE POSSIBILITY ON A TOSH. POCKET PC e405
Yes your pocket pc has one sd memory card free so you can put another 64 mb of SDRAM card.
Posted on Jul 24, 2009
sonu_sehgal
  • 421 Answers
SOURCE: Toshiba pocket pc e 405
no you cant update
Posted on Aug 08, 2009
MY granite sink arrived and a large corner of the back where the holes are for the faucet is broken off. Since I have had the sink swince Feb. 18th unopened unmtil tonoght I don't think the company or UPS...
I would think it is worht a try. use some epoxy for granite and also glue something to the underside of it to beef it up, plus it will help hold the break togather with a clamp or two.
Mar 08, 2011 | Granite Home
The foam coil came apart the rim of the frame...how do you glue that back togather?
If its the foam around the lip then you can use apoxy glue or something of that nature. Just remember you want the glue to be rubber type glue and not hard glue. I've used the sealant you buy for transmission pan gaskets before and its still holding.
Nov 25, 2010 | Rockford Fosgate (P212D4) Car Subwoofer
How can i connect my toshiba e405 pda with computer?
you need an USB data cable (compatible w/ e405) and you need the ActiveSync software...
Note when connecting to pc both devices should be off
Oct 17, 2010 | Toshiba e405 Pocket PC
How do I change the battery in My E405
you can get new batter from your compny that you get your phon from
Feb 14, 2010 | Toshiba e405 Pocket PC
Jul 24, 2009 | Toshiba e405 Pocket PC
I cannot find out how to open a toshiba e405 to replace battery.
The instructions are posted as a pdf file on the following site: http://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=UP423467&model=E405
I will try it too. BK
Dec 11, 2008 | Toshiba e405 Pocket PC
Mar 13, 2008 | Toshiba e405 Pocket PC
SD card
Hi There
you need to format the SD card using any card reader and only then you will be able to use your SD Card in your PDA.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 20, 2008 | Toshiba e405 Pocket PC
Can not connect my PDA
Hi __Try to Uninstall the toshiba software. Also search for the Folder called Toshiba and remove that as well.____Then Re-Boot Your machine. ____Re-Install the Toshiba software and that should work.____If not we can do a live meeting and I can help you troubleshoot the problem.____VR____JustAskMe
May 04, 2007 | Toshiba e405 Pocket PC
Toshiba e400 Pocket PC Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
