If the igniter is replaced but the problem is same then there are two possibilities that has to be checked.
1) Bad gas safety valve.
2) Bad control board.
To check this parts try this procedure:--
Remove the wires from the gas safety valve and check for continuity between the terminals. If there is no continuity then the gas safety valve has to be replaced.
If there is continuity then the control board (aka a clock) has gone bad.
You can get required parts from
www.repairclinic.com or from www.partsselect.com
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
