Question about Dell 2300MP Multimedia Projector
Will not turn on
Heard a loud pop. Though it was the bulb. Replaced it and it still won't turn on. Any ideas?
  • 22 Answers
Check out the electrolytic capacitors on your Low voltage power supply board...they over heat, expand and pop...very easy to see...blown caps...
Art
Posted on Aug 02, 2010
Popped lamp, rapid clicking after replacement
Take it out and get in there with a vacuum. There are fans that keep it cool and there is a color wheel that might be damaged. All those shards need to be removed
Jan 22, 2014 | Mitsubishi Diamond WD-65831 65" Projection...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My 2000 Sable won't move though gear selector appears to be in tack. Was making a left turn heard a loud pop on the right front side of the car then what appeared to be a rubbing or scraping noise...
the problem has to be in the linkage inside the transmission which means that you have to take into a mechanic to have them fix this because if you do not know how to take the transmission apart yourself is the reason why to take it to the nearest mechanic. Sorry
Jun 09, 2011 | 2000 Mercury Sable
Projector had been overheating so we cleaned out the filter. When it was turned back on there was a loud pop. We turned off and turned back on, red lights started flashing and the fan roared loudly and...
The projector lamp has probably failed. If it had been overheating, the glass for the bulb would be weakened and then eventually when turned on the glass shatters, the pop you heard. Bulb replacement is usually a straight forward user replacement item. Ebay is often your best choice to get a bulb at a reasonable cost.
Mar 29, 2011 | Office Equipment & Supplies
We heard a loud pop and the tv turned off and
That sounds like the lamp bulb blew and you will need to replace it. You can find ads on this web site that sell DLP bulbs at a decent price and you can install it yourself, or you can call 1-800-samsung to find the nearest service center.
Jul 16, 2010 | Samsung HCM4215W 42" Rear Projection...
Heard a loud pop during turn on, not picture but
Ur LCD inverter board it dead.Replaced this board u will get ur picture back.Tries websites like shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 26, 2010 | Toshiba 32HL66 32 in. LCD HDTV
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
2000 Diamante, Timing Belt ? Loud pop, explosion, bang...
sounds like the belt tensioner. look for any drive pulley that doesn't actually drive anything but is turned by the belt... that is spring loaded and keeps tension on the belt... if it moves freely... it needs to be replaced.
Mar 14, 2009 | 2000 Mitsubishi Diamante
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Dell 2300MP Multimedia Projector Logo
254 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
