Question about NComputing X300 3 User Expansion Kit Graphic Card
I have an internal error in my 3 terminals X300 0x2025 0x08x-0
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Error code ch 05
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
Hi there, we had blackout last night and our ac unit mitsubishi electric has an error code E6 is coming up! how can i fix this problem?Thanks
E-6 Indoor/outdoor transmission error. error.
Jan 23, 2011 | Heating & Cooling
I have an LG inverter split system which is coming up the error C5. What can I do to fix this problem?
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Jan 06, 2011 | LG Heating & Cooling
Hi, have a split system 10 years old, unit on wall has one green light flashing 5 times and repeats. Patrick
E5 Communication error between outdoor and indoor
Helpful?
Jan 01, 2011 | Mitsubishi Heating & Cooling
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
What is error code ch o5
CH-05 Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Oct 06, 2010 | LG LSC183VMA Split System Air Conditioner
Error code F1 Confort Star ceiling console
F-1-Noc ommunicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Aug 26, 2010 | Comfort-Aire PAC-121 Air Conditioner
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jul 27, 2010 | LG L1004R Air Conditioner
NComputing X300 3 User Expansion Kit Graphic Card Logo
1,745 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
john cordey
john cordey
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
