Question about AmcorAire UCHW-H18AF2 Split System Air Conditioner
Chargeing Unit Standard chargeing hoses do not fit this unit. What size do I need?
    Scholar:
  • 66 Answers
The old 410A fittings are different than the r-22 fittings. There are adapters available on ebay. Remember 410A runs at higher pressures than 22. Be sure to use gauges for 410A! Use the right gauges with the right hoses! High pressure.. Use the right gauges and the right hoses!
Posted on Jul 31, 2010
Does anyone know what size bolt holds the high pressure hoses on under the ps pump on a 03 chevy trailblazer? Have tried every known tool I have. Invert torx,stand,metric. Thank you
You remove the high pressure line using a standard imperial open ended spanner on the fitting where the steel HP line attaches to the PS pump unit.. It will most likely be around 5/8". But, if not that size, if you have a decent range of imperial size open ended spanners you should have no problem finding one that fits perfectly. If you don't in your spanner set then slide an adjustable spanner over the fitting, adjust it up to the bolt on the HP line and then remove and measure the size. Buy a spanner that size (the longer the better) and you should have no issue removing the line as long as the bolt head has not been rounded off.
Jan 28, 2016 | Cars & Trucks
My tablets female chargeing inlet will not let the tablet charge.
Try another lead in your unit to rule out a faulty lead. Try your lead in another unit and if that works your tablet may be faulty. If your tablet works whilst plugged in but switches off when you disconnect it may be a battery problem.
Oct 05, 2015 | Tablets & eReaders
How do you charge your air conditioner unit
The reason the fitting is too small is that is the HIGH side fitting ,look for a larger fitting in one of the larger size hoses or tubing
Jul 01, 2014 | 1998 Buick Regal
Wm1355hw
yes washing machine hoses are standard size and available at places like Lowes, Home Depot, anyplace that sells appliances. You can get the ones you want with the stainless overbraid to fit your washer.
May 14, 2014 | LG Washing Machines
Does this unit fit into a 2007 montana van
This unit will fit into your van. There will be extra space in the dash after you install it. The standard measurement technique for head units is DIN. A single-DIN unit is the normal size of a head unit. Your stock unit is a double-DIN unit. The Clarion NZ500 is a single-DIN. It will fit, with space to spare.
Mar 08, 2011 | Clarion NZ500 Car Video Player
Toshiba Satellite P305D-S8828 no charge battery
sounds like batterys not chargeing mite need new battery....or your ac power unit is not getting to the battery. lala linda
Jun 15, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
May 16, 2009 | Karcher PSI Electric Pressure Washer
Franke Little Butler instant hot water dispenser
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Apr 13, 2008 | Franke WD751B GPS Receiver
My gramin c330
my unit is new a xmas gift.i have 3 ways of chargeing the unit.when you charge it in the house do not turn unit on till after the unit has charged.in the car plug it in and the picture of the battery goes away that is telling you it is chargeing in the care.gram6
Jan 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
AmcorAire  UCHW-H18AF2 Split System Air Conditioner Logo
143 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
